ability to now configure the Wall Framing Label display of a generate
wall panel drawing. You are able to select between Width & Depth,
Depth & Width, or No Dimensions.
In order to demonstrate this feature,
you will need to be in the Framing Mode within SoftPlan. If you do not
have a drawing to use, simply select one of our sample drawings provided
with the program.
