Walls
6" Concrete Wall Definition Added to Lite
Banding Finish Options Added
When drawing banding, a list of default finish options is available. A profile view of these options is available in the Draw Polygon box.
Banding Profile Added
Block Cut of a Raked Wall Maintains Plate Heights
Blocking (Framing) in Curved Wall Improved
Cover Floor Option Added to Edit
When selected the outside wall material is ectened to cover the floor system. This was formerly done only if sub-floor was present.
Corner Board Size Can Be Edited on an Individual Basis
Curved Wall Appearance Improved in 3D
Curved Wall Change Wall Properly Maintains the Outside Radius of the Wall
Definition Option Added to Wall Edit Dialog
This feature opens up the Wall Definition dialog for the selected Wall. The wall definition can then be edited for the wall type selected.
Fit To Stair Command Added to the Edit Wall Dialog
Inner Most Alignment Option Added To Edit Wall and Change Wall
When the change wall command is used the option to align walls using the inner most part of the wall is now available.
New Wall Textures Block Reversed Added
Rake Bottom Command Added
Select & Edit Multiple Fields at the Same Time on Wall Definition Dialog
Step Wall Command Added
Based on the inputs of number, length, height and start point of step, the Step Wall command takes the existing wall and automatically creates individual wall sections of required length, height and offset.
Stone Walls Added to the Extended Wall List
Strapping Wall Material Added
Stucco B Added to Wall Materials
Stud With Drywall on One Side Added to Remodelers Wall Definition
Tar Material Added
Wall and Beam Definitions Can Utilize Profiles
Wall Join Tolerance of Zero Allowed
Wall Joins Improved in Situations Where Short Walls Join Each Other
