Wall Framing
Add Header Command Added
This command is used to place a single header over multiple openings.
Blocking on Raked Walls Improved
Draw Select Will Select Individual Studs
Framing Dimension Defaults Added to Character Setup
Individual Studs Can Be Added, Removed, or Relocated
Individual Studs Can Be Extensioned/Dimensioned
Header Position Within Wall Thickness Added to Edit Dialog - Inside, Outside, Spaced
Jack Stud Count Option Added and Number of Jack Studs Can Be Specified on Opening Edit
Pocket Doors Framing Improved
Studs Can Be Modified from 2x to 4x for Shear Wall Applications
Snap Located Points on Individual Studs
Stud Spacing of Individual Walls Can Be Changed
Stud Thickness Can Be Changed on Individual Wall Types
Studs and Modified Studs Display in Different Colors in Framing Mode
