| Adjust Wall Material Command
Added |
| Difference Command
Added |
The Difference command is used to
compare the changes between two versions of the same drawing.
Using the Difference command allows you to highlight the changes that
have been made between the current drawing and another selected
version of the drawing.
| Fillet Works on Curved
Walls |
Insert Polygon Edges
Command Added
Existing polygon based items such
as rooms, decking and joists can have addition corners added to their
shapes by using the Insert Polygon Edges command.
| Reduce Wall Join Tolerance
Added |
Select a wall join and all the
participating walls will automatically have the wall join tolerance
decreased, used to properly form corners where many corners are in
close proximity to each other.
