| Generated Grade Lines Automatically
Display a Shot Point at Each End Indicating Height |
Grade Lines can have the elevation
changed via the edit dialog. Select the Site Polygon tab from
the Edit Grade Line dialog and the elevation for the entire grade line
can be changed at once. Editing the elevation of a grade line
automatically changes the elevation for all the shot points along the
grade line. This will make creation of site topography easier.
| Grade Lines Can Be Drawn as a
Spline |
When sketching a grade line onto
plan, SoftPlan allows you to make the choice of adding the line as a
spline if desired.
| Grade Lines Slope Site by
Default |
| Enhanced Site Poly
Entry |
Site Polygons can be placed either
with a line/spline boundary or as a line with a width assigned.
For example, a patio may be drawn as a polygon enclosed with lines. A
planting bed may be a closed spline, a driveway a 20' wide object
centered on the garage door, and the walk as a 4' wide object that has
the edges aligned with the house. The ability to place site polygons
as a line based polygon, makes drawing site plans easier.
| Intersection of Two Polys Added to
Snap |
| North Arrow Direction Can Be Changed via
Edit of the Arrow Itself |
| North Arrow Symbols Automatically Point
North |
| Polygon Tab Added to Site
Polygon |
| This Polygon tab allows the entire site
polygon to be edited for various properties including type, depth, and
offset. This tab allows the entire elevation of a site poly to be
changed. |
| Polygons Will Display as Shaded
on Site Plans |
| The site polygon displays on the site
with a shaded fill. |
| Reverse Option Added to Site
Line |
| The Reverse option, when selected,
changes the description of N 45 E to S 45 W. Note that the line itself does
not change just the description. |
| Shot Points Display in the Same
Color as the Item That They Modify |
You now have the option to display
shot points in the same color as the items that they are modifying. This
feature is turned on by default. If you would like to display shot points
in a different color you may uncheck the item.
Site Polygon Offset Field Allows
Grade Lines to Slope Site
| Site Polygons Can Be Moved Up and Down in
SoftView |
| Site Work Polygons Can Be Entered Using
the Options – Align Edge, Align Center, and Width |
