Roof
Add Shed Roof Command Added
Adjust a Roof Reference Point onto a Curved Wall and the Roof Edge Becomes Curved
Apply Gable Command Added
Arc Roof Profile Improved
Auto Roof Improved
Auto Roof Works Across Multiple Floors
Auto Stick Frame; Placement Improved
Clip Roof to Wall Command Added
Color Added to Roof Planes in Plan
Cricket Placement on Intersect Roof Edges Improved
Dimension and Extensions Added to Valley/Ridge of a Double Hip
Dominate Selection Added to Roof Edge Edit
Draw Roof Plane (3 Sided) Added
Dutch Gable Extensions and Dimensions Can Be Added
Dutch Gable Roof Improved
Dutch Gable Hip Portion of the Dutch Gable Can Have a Pitch Different from the Adjacent Hip Roof Planes
Edit Roof Edge Easier to Select from SoftView
False Gables That Reference a Beam Move Up the Roof When Moved
Fascia & Soffit Improved on Multiple Floor Roof
Fascia Extraction Improved
Fit to Roof Works on a False Gable
Fit Wall to Roof on Multiple Floor Roofs Improved
Gable Roofs That Are Offset and Intersecting Are Improved
Gable Vents Have the Same Trim Options as Regular Openings
Gutter Can Be Added to a Roof Edge That Does Not Have a Fascia
Intersect Edges Can Have Two Pitches
Match Roof Planes Automatically Sets the Wall to Fit to the Roof Plane
Match Roof Planes Command Improved
Plate Heights Display Different Heights in Different Colors
Reference Points Set to Ignore Wall Display in Construction Color
Ridge Can Be Extensioned and Dimensioned
Ridge Cap Entry Added to SoftView Extraction Options Dialog
Roof Edges With Horizontal and Vertical Pitches Are Ignored When the Pitch of the Entire Roof Is Changed
Roof Type Option Added to Edit (Cricket, Saddle, False Gable, Bay and Opening)
Saddle Edit Improved
Shed Roof Fascia and Soffit Formation Improved
Shed Roof Formation Improved
Snap Points Added
Soffit on Roof on Opening Improved
Type Erase Entry for Roof Added
Valleys Formed By Intersecting Planes of Different Roofs Display in Plan
Walls Used in Multiple Floor Roof Are Available to Snap
