Arch Chamfered Maintains the Size of the
Chamfer As the Width of the Arch Is Changed |
Baseboard Wraps Around Arch Openings if
No Other Trim Is Added |
Bottom of Opening Position Field
Added |
Cased Openings Added to Arch
Library |
A cased style opening can has been added
to the Arch library. |
Center Opening Now Asks to Center
on the Inside of the Room or the Outside of the Building Where
Applicable |
When centering openings, you may
now choose between centering them along the inside of the room or the
outside of the building.
Colonial Trim for Openings Added to
Profiles |
Corner Blocks Added to Opening
Trim
Double Entry Doors Added to
Default Library |
The double entry door has been added to
the doors library. |
Elevation Opening Trim Can Be Added to
Layers and Building Options |
Ellipse Shaped Openings Have Multiple
Radi |
Face Sliding Door Type
Added |
Grille Thickness Option
Added |
In the Material Dimensions for
Opening Options, SoftPlan now allows the user to set a thickness for
grilles.
Grilles on Polygon Type Opening
Improved |
Header Span Tables Updated to Meet 2006
IRC |
Interior Trim Has All the Properties of
Exterior Trim Including Profiles, Corners, and Overhang |
Number of Grilles Can Be
Specified |
Only Openings Included in SoftList Appear
on the Opening Schedule |
When generating an Opening Schedule, by
default the Only add openings included in SoftList feature is turned on.
Using this feature, only openings that will be counted in SoftList will be
added to your Opening Schedule. |
Opening ID Placement
Improved |
Opening Offset Within Wall Thickness Set
at the Instance Level |
Opening Schedule Will List Frame Width
(Jamb Size) |
Opening Size Placement Has Been
Refined |
Opening Text, Product Code, ID, Size,
Rough Opening Can Be Automatically Added to Saved
Elevations |
Opening Trim Can Be Inset into the Wall
as With Frieze, Corner Boards, and Banding |
Opening Trim on Interior Non Symmetrical
Walls Places Interior Trim On Both Sides of the Wall |
Prarie Style Grille
Added |
A praire style grille can be added
to a window through selecting the praire style option on the grille
tab.
Profile Mode Highlights the Opening Being
Edited |
Renumber Opening Id’s Command
Added |
This special command in Version 14
helpfully renumbers all openings on drawings in the assembled floors list to
remove any gaps. |
Screen Option Added for
SoftList |
The screen option may be checked
on an opening. This is used for the purpose of SoftList making an
accurate materials calculation.
Separate Interior Trim Control Added for
Above, Below, And Sides |
Tall Doors Added to
Libraries |
Typical 7' 0" and 8' 0" have
been added to SoftPlan's opening libraries. |
Taper Option Added to
Trim
Opening Trim Taper option has been
added to the Exterior Trim tab of the Edit Opening dialog. This
option forces the sides or ends of the trim above the opening to follow
the slope of the Keystone. This can be used to create sloped
soldier courses or to angle the end of wood or stucco trim.
Tempered Glass Column Added to
Opening Schedule |
Tempered glass and grille have been
added to the opening schedule as an option to be added. |
Trim on Complex Shapes
Improved |
