Move
Align to Edge Can Access Walls on an Overlayed Drawing
  The Align to Edge can be used in a situation where one object on a plan needs to align its edge to the edge of another object. This command can be used on any object and provides a more precise way of moving objects that will be aligned with each other.
  Lock State Is Maintained When More Than One Item Is Moved in Succession
  Move of Angled Dimensions With Tails Improved
  Select Base Point Move Added to the Status Bar When Move Block Is Used
  Shapes Will Attach to Box, Circle, Triangle, and Polygon
