| Lathe Template Used to Create
Turned Profiles to Be Placed Into the Lathe Library |
| Use the Lathe Template to create custom
shapes for the stairs Posts, Newels, and Spindles. The Lathe allows you to
“convert” custom profiles out of square stock that will be used on the 3D
model and the generated working drawings. |
