File
 DWG and DXF Export of a SoftView Model Can Include Textures
  DWG AutoCAD® 2007 Files Import
DWG/DXF Export Layers Can Be Assigned to Every Object Type
  DWG/DXF Import Brings in Meshes
DWG/DXF Import of Drawings with Mirror and Rotated Blocks Improved
  DWG Import of Splines Improved
  DXF/DWG Import Is Faster
DXF/DWG Import, Items Located Outside the SoftPlan World Will Be Automatically Moved to the SoftPlan World Where Possible
  DXF/DWG Import of Drawings Containing Proxy Items Improved
Import DXF With Multi Line Notes Improved
  Metafile Import Added
  Partial Option Added to Multi Drawing Command
Multi Drawing allows a partial drawing to be added to a Multi Drawing. Selecting Display Portion of Drawing prompts for the part of the drawing to be displayed and the scale to be used.  This will be useful for displaying portions of a large drawing at an increased scale for detailing purposes.
