Access to Wall and Beam Definition Added
to Wall and Beam Edit Dialog |
| Answer to the "Align" Question on Edit
Wall Is Maintained for the Entire Session |
.When changing a wall from one
type to another, the selection you make in how the walls should align
during the edit is kept for the rest of the session.
| Block Form Polygon Command
Added |
| The block form polygon command takes all
possiible items in a block and forms polys. |
| Change Wall Will Not Introduce a
Wall Thickness if the Source Wall Did Not Have a
Thickness |
| The change wall command will not added a
wall thickness to the source wall if the wall did not have a thickness
originally. |
| Item Cleanup Added to Each
Item |
In Version 14, items
must be partially on the screen to be located by the erase tool.This
will prevent inadvertantly erasing large items that you can't see such
as Site polys
Paste from Windows
Clipboard Command Added
The contents of a the Windows
clipboard can be pasted directly into the SoftPlan drawing. Four types
of items can be created in the drawing: Text places unformatted text
into the drawing, Multi Format Text is used to paste text from
applications such as Microsoft Word that maintains all formatting,
Metafile Image for items from Excel, and Image for raster files
including raster versions of PDF files.
Step Wall Command
Added
| Based on the inputs of number, length,
height and start point of step, the Step Wall command takes the existing wall
and automatically creates individual wall sections of required length, height
and offset. |
