Add End Panel Option Added to
Rod & Shelf
Drawings in Memory Are Indicated With
a Graphic Icon on the Status Bar Drawing List
| Elapsed Time Has Reset Option
Added |
| Multi Drawing Zoom and Pan Can Be
Used While Placing a Drawing Within the Multi |
| The ability to zoom and pan when placing
a drawing on the multidrawing has been improved. |
| Information Popup Added to Right Mouse
Button |
| Selecting the right mouse button presents
a context appropriate menu. If there are multiple items near the cursor, a
locate type menu appears. The menu selection then changes depending on the
type of object under the cursor to display appropriate drawing actions.
If no object is under the cursor, a mode appropriate draw menu will appear.
This feature greatly reduces the amount of mouse movement required when
working in SoftPlan, enhancing the drawing speed. |
| Multi Drawing Displays Current
Mode in Drawing Selection Dropdown When Multiple Copies Present in
Drawing |
| When multiple copies are present in
drawing, multi drawing displays the current mode in the drawing selection
dropdown. |
| Rod & Shelf Command Allows Multiple
Shelves |
| The Rod & Shelf edit allows for
placement of multiple shelves. Users control the number, depth, offset, and
spacing of the shelves. This is useful in designing closets, as well as, for
items such as bookshelves, if the rod is excluded. |
| Rod & Shelf Settings Added to
System and Drawing Options |
Settings for rod and shelf may now
be modified using System and Drawing Options. Edit defaults for
thickness, offset, spacing and more of rod and shelf.
