Beams Can Be Added in Roof
Mode |
Beams can be added in Roof
mode. This function is useful when creating ridge and valley
beams. Like other beams drawn in SoftPlan, beams added in Roof
Mode can be edited to meet design specifications.
Dimension and Extension Placement
Control Added |
The placement of dimensions and
extensions on beams can now be specified using the Dimension and
Extension Format Option in Systems Options. Beams previously used the
wall setting.
Fit to Roof or Ceiling
Added |
Length Displayed in the Edit
Dialog |
When editing a beam, the length of
the beam is displayed in the edit dialog.
End Style Selection
Added |
The end style of a beam can now be set to
either Plumb or Rake. |
Profiles Added to Beams Ends Allowing for
Creations of Shapes |
Beam Materials can be defined with user
defined Profiles. The Profile shapes are stacked directly on top
of each other when the wall is viewed in SoftView. A Log wall is
an example of a material that would be defined this way.
Steel Beams with Plates
Added |
