| Area Exclude Rectangle Command
Added |
Area Exclude options have been
added to Area Mode. Using an exlude command allows sections of an
enclosed area to be excluded from the total area
| Area Schedule Command
Added |
| An area schedule may now be generated
using either the current drawing or drawings from the assembled floors list.
The Generate Schedule dialog provides this option when generating an area
schedule. |
| Color Added to the Area Tally
Box |
To easily indicate each area,
color swatches have been added to the area tally box for user
reference.
| Drawings in Assembled Floor List Option
for Schedules |
Allows the schedule
report data from all floors on the Assembled Floor
List.
| Duplicate Added to
Area |
| The Edit > Duplicate command will act
on Areas; to change Area Type for example. |
| Repeat Edit Added to
Area |
| The Edit > Repeat Edit command will
act on Areas; to change Area Type for example. |
| Show Polygon Shaded in Visible Items Will
Shade Area |
If you select Options > Visible
Items > Show Polygon Shaded this will displays areas with a shade
rather than a hatch pattern. Note that the shade is for display only
and it does not print.
