Add Plate Under Header Option
Added |
A new Framing option for ‘Add
Plate under Header’ is available to automatically add a plate between
the header and top of the opening.
Adding Additional Slab
Footings to an Existing Structural Slab
The ‘Slab Footings’ command has
been added to Floor System mode. This command will allow placing
additional footings beneath load bearing walls. Slab Footings will tie
into the footings from Structural Slabs. This is useful for generating
monolithic slabs or floor beam (grade beam) systems.
Align Studs on Floor Joist Option
Added |
The ‘Align studs on Floor Joist’
option has been added to the Wall Edit. By selecting this option,
SoftPlan will align the studs of the selected wall to align with the
joists running in the same direction. The alignment is determined by
the largest joist span along the selected wall.
Corner Style Single Stud
Added |
New options for how the studs are
framed at corners have been added to the Framing options. These
options are available in the ‘Form Corner’ selection. They include
Single Stud and 4 studs.
Edit Slab Edges and Footings on
Structural Slabs |
Individual Slab edges can be
edited on Structural Slabs and the new Slab Footings to set the
properties for each.
Edit Walls in Framing
Mode |
Version 13 allows changing framing
options on an individual basis with a Wall Edit. The Framing menu
appears for the selected wall, where properties can be changed, such
as: the ID number, how the wall ends are forming with adjoining walls,
and the stud placements in the wall.
Framing Style Can Be
Differentiated on Each End of a Wall |
Now that Version 13 provides
editing walls on an individual basis, this gives the flexibility of
defining different Stud framing options for each wall end.
Generate Non-Framing Walls Option
Added |
With the ‘Generate Non-Framing
walls’ option selected, non-framed walls such as ICF, concrete or
other wall panel systems can be generated into Wall Panel diagrams and
Plan view diagrams by using ID numbers.
Show Electrical Holes Option
Added |
This new Framing option will
indicate cutouts in Wall panel construction wherever basic Electrical
services have been placed along walls. These will be represented as
boxes in Framing mode, as well as, the generated Wall panel and Plan
View diagrams. Offsets are determined by the offset assigned to the
Electrical symbol.
Stud Offset Option
Added |
This feature can be accessed on a
Wall Edit in Framing mode. The Stud Offset allows entering an offset
distance for the stud which will be from the beginning of the wall to
the beginning of the second stud. This offset distance is based on the
selected Start Side of the wall.
