Snap
  Center of a Curved (Radius) Wall Is a Snap Point
The Cursor Snap command is now able to locate the Center radius point of a curved wall.
Posts ‘Points’ Added
When using Cursor Snap with a relative command it is possible to locate a specific point of a Post which includes the center, midpoint, and corners.
Railing ‘Points’ Added
  When using Cursor Snap with a relative command it is possible to locate a specific point of a Railing which includes the center, midpoint, and corners.
Overlay Lines From the Overlaid Drawing Are Available
The Snap function will now snap to overlaid walls, beams, and posts. Once a drawing is overlaid and a command such as, line or wall is active, the snap command can be selected in the Tools menu by hitting F11. By clicking near the end of an overlaid object, the command such as line or wall will start at the end of that object.
Wall Midpoint Added
With the further development of Cursor Snap locations, the Wall midpoint has now been added. This is useful when needing to draw Beams, Walls, Symbols, or other items that will originate from the midpoint of a Wall.
