36” Wide Interior Doors Added to
Library |
SoftPlan has provided more sizes
of standard Interior doors which include the 36” wide.
Add Brick Check Option
Added |
A new Opening Option for a “Brick
Check” has been added. When selected, this option will apply to all of
the Openings on the drawing. It will extend the brick (masonry)
material of a wall by 5/8” into the Rough opening space. This is often
used in marine climates to create a water-tight composition around
Opening frames.
Add Transom Command
Added |
Transoms can easily be added to
any existing Opening on a plan. This is done with a simple Opening
Edit and selection to add a Transom. This feature will create a new
Product Code by modifying the existing one and add a casement window
over top at a specified height.
Auto Slope Top Elevation Opening
Style Added |
Within the SoftPlan Openings
libraries is a new type of window called ‘Trapezoid.’ This window is
different in that it has the ability to automatically adjust the
sloped side to match the pitch of the top plate of the wall. Assuming
that the wall has been ballooned framed to the underside of the roof,
then by extension, the window will match the roof pitch.
Cottage Window Style
Added |
Version 13 has the ability to
create cottage style openings. These openings have sashes of different
sizes.
Equally Spaced Openings Command
Added |
Version 13 provides an easy-to-use
command for equally spacing out multiple openings along a wall. Simply
select the wall and decide if the openings are to align according to
the inside or outside length of the wall.
Exterior Trim Profile Option
Added |
Openings now have the ability to apply
detailed profiles to the Exterior Trim. These will be reflected in 3D
models. |
Garage Door Hinge
Designation |
Garage Doors now have a default
hinge side designation that will be shown on the saved Elevation
drawings.
Garage Doors – Rough Opening
Width Can Be Less Than Opening Width |
With Garage Doors, the Rough
Opening Width can be set to a value less than the Opening width. This
feature gives the ability to set a Garage Door to the inside of the
wall, as this will allow for a built-up system for overhead garage
doors.
Hardware (Handle) Option Added to
Doors |
Now it is possible to add even
more detail to Doors. Version 13 has the addition of a Door Hardware
library with various handle options that can be applied to doors.
These will be reflected in the SoftView 3D model.
Hide Threshold Option
Added |
The plan outline of the Opening
threshold can easily be turned on or off with this option.
Hole Cutting of Complicated
Openings in Walls Improved |
The holes cut around openings have
been improved to work for more complicated shapes. This includes round
top openings placed on angled walls in the plan. These holes are
needed to closely cut out the section of the wall from around the
Opening symbols, which will be shown in SoftView.
Interior Casing Profile Option
Added |
apply detailed profiles to the Interior Casing. These will be
reflected in 3D models.
Open in SoftView Option
Added |
This is an excellent tool to use
when doing walkthroughs of the proposed building. When this option is
selected, you can move freely through unobstructed entryways in the
SoftView 3D model. Openings will display open according to the angle
assigned to them, which can display a door partially or fully open.
This allows you and your customer to gain a greater view of the
building using SoftView as a visual aid.
Opening ID Added to
Openings |
With the new Opening ID feature,
labels can be applied to all Openings on a drawing. SoftPlan can then
automatically generate the Opening Schedule to include this
information.
Opening Libraries Folder and
Sub-Folders Added |
The structure from which Openings
are drawn has been changed. Openings are now set-up in a tree format.
The Opening Libraries can be expanded to select sub-folders for more
specific categories of openings. More options can be seen at once with
this new format.
Opening Schedules - Width,
Height, Rough Opening Width, and Rough Opening Height
Added |
With these new additions to the
Opening Schedule options, Width, Height, Rough Opening Width, and
Rough Opening Height can be added as separate entries. These options
give the flexibility to choose which dimensions will be shown on the
generated Opening Schedule.
Openings Are Automatically
Centered in a Wall When the Opening Width is Greater that 50% of the Wall
Length |
This is a terrific feature to be
able to center Openings when the width is greater than 50% of the wall
length. For example, when placing a garage door, it is no longer
necessary to manually center the opening along the length of the wall
it is placed on. SoftPlan recognizes that it is wider than half the
wall length and automatically centers it when drawn.
Shutter Option Allows for
Placement: Left, Right, Both |
This option provides more
flexibility with the placement and design of Opening Shutters. Version
13 now has the ability to apply the Shutter type to the Left, Right,
or apply to Both sides of the Opening when the Shutter option is
enabled.
Shutters Display as Non-Printing
Items in the Plan |
When Shutters are enabled for an
Opening, there will be a profile shown in plan view outlining them.
This feature is for display purposes to ensure that the Shutters have
been applied. The outlines will appear on the drawing screen but will
not be printed with the floor plan.
Shutters Extract as Multiple
Surfaced 3D Symbols |
The standard Shutters available in
Version 13 have been linked to a corresponding 3D symbol. These 3D
symbols were created with many solid surfaces that include
indentations, paneling, and other details that provide a more accurate
representation for the 3D model. Many more Shutter styles have been
configured and added to this Standard Library.
Tempered Option
Added |
The Tempered Glass option can be
applied to any Opening. This will provide the basis to be able to
specify these opening types within a SoftList formula by using the
corresponding variable ‘has_tempered_glass’.
