Copy
Group Is Available as a Selection Item to Allow Groups of Items to Be Copied
 When the Copy command is used, the Group option can be selected in the status bar. This is helpful when needing to make multiple copies of grouped items.
  Multiple Placement Option Added to Copy and Block Copy
Continuous copies of objects can be made with Copy or Block Copy when the option for Multiple Placement is selected. Copies of the same object(s) can be continued to be placed anywhere on the plan. This saves having to reselect the option to make more copies, or having to move objects into their proper position after multiple copies are made.
