Beams
  Adjust Height to Fit to Beam Option Added to Posts
In past versions of SoftPlan, the Posts needed to be edited for height to make sure they would come up flush to the underside of Beams. Version 13 gives you the automation for a Post to recognize and calculate the proper height to have it meet a beam drawn above by simply selecting this option in the Post Edit menu.
  Beam Selection Dialog Made Larger to Display More Walls at Once
The dialog where a beam is selected to draw will now display with a longer listing. This saves time from having to scroll through a shorter list, as well as, allowing to more easily make a selection.
  Beams Visible in All Modes
Beams can be drawn in either normal Drawing mode or in Floor System mode. The ‘Visible in All Modes’ option allows the beam to be seen when the mode of the drawing changes, or to only be visible in the mode it was drawn in.
  Drawing Support Beams in a Floor System
Support Beams can also be drawn in Floor System mode if you require additional support for the floor joists. Beams drawn in Floor System mode will default to the bottom of the floor plan, placing the beam flush with the floor system. Floor joists can then be drawn to hang from the support beams. Drawing beams in Floor System mode is the same as drawing beams in the normal drawing mode.
  Flush Beams Added to Floor Systems
When drawing Beams in Floor System mode, they will draw flush with the bottom of the Beam at the top of wall (from the plan below). The Beams will be placed at the bottom of the current floor plan set at the zero baseline.
  Import/Export Allows Individual or Groups of Beams to Be Moved from System to System
Version 13 offers a much more flexible way of customizing Beam lists. One benefit is the ability to pick and choose what specific beams to Import and Export from the list. You can choose individual or groups of beams for transfer.
Another new benefit is the ability to take Beams that were created within an existing Drawing and adding them to the System to use again in another project. When Exporting, you can select which beams are to be saved to a File. When Importing, you can select which beams to take from the System to the Drawing level; the Current Drawing to the System level, or from an exported File.
  Sloped Beams Are Now Possible
Within the Edit menu for Beams gives the ability to select to Slope beams, where one end of the beam is set at a different offset than the other end. This can be used in applications where support is needed but will not be horizontal.
Copyright©2006 SoftPlan Systems Inc.
