@Area Print Command Added to
Automatically Print the Requested Area |
By simply adding a SoftPlan
Information Stamp as a Note to the drawing, the corresponding area
from Area mode can be printed. For example, use @area2 and it will
replace this Information stamp on the printed page with the actual
square footage for the corresponding area. This can be used alone, or
in conjunction with generated schedules to update area information
from the drawing.
Dimensions and Extensions Can Be
Added to Area Mode |
Dimensions and Extensions can be
added in Area mode as a default setting. This gives the ease of
dimensioning the walls in the plan, along with the display of the
respective areas.
Schedules of Areas Can Be
Generated |
It is a great feature to have an
automated process of generating Area Schedules. Simply select the
option from the menu and click on the drawing screen to place the
schedule. It will include all areas that have been drawn in Area mode
in a table format.
