Build Menu Automatically Opens When the Assemble Floors Dialog is
Closed
Version 12 has added a feature to
speed up the process of generating in SoftView. When the Assemble Floors
is selected and the floor plans are assembled to build, once the menu is
closed the Build menu pops back up again allowing you to choose which
option to generate.
Go to Build > Assemble
Floors.
Add in the floor plans to
build.
Click OK.
The Build menu pops up again
since the next step in this process is then to generate in
SoftView. This allows the selection of 3-Dimension, Elevation or
Cross section without having to reselect the Build menu. The
cursor will become active on the Build menu in order to quickly
select one of these options.
Gable Roofs with Raked Fascias Generate “cleaner”
Elevations
SoftPlan Version 12 has improved the
automatic generation of gable ends in elevation when the fascia is
specified to be raked. Previous versions of SoftPlan added an extra line
in the gable end corners when the fascias of the adjacent hip edges where
set to be raked. These extra lines are no longer generated resulting in a
much cleaner elevation automatically and thus eliminating the need to
erase these lines in the saved elevation drawing.
Plan Post Added to Camera Position
Version 12 now displays plan posts
while positioning the camera in SoftView.
- Generating a 3D view.
- Click on the Camera icon. The right
hand pane of the ‘Camera Control’ dialog will display the plan
posts.
posts.
Drawings in Assemble Floors Appear at the Top of the Drawing
Selection Drop Down
A new feature to SoftPlan Version 12
is the order of the drawings in the Drawing Selection drop down in the
Status bar. Those drawings listing in the Current Assembly side of the
Assemble Floor menu will appear first in the Drawing Selection drop down
in the same order of which they where assembled. Those drawings not in the
Current Assembly are listed in alphabetical order after a line separator.
This allows drawings that are more frequently opened to be located more
readily.
Select Build > Assemble Floors.
Highlight the lowest floor plan drawing (example:
Foundation Plan) and select the Add button.
Continue highlighting and added additional floor
plan drawings until all floors are assembled.
The next time the Drawing Selection drop down in
the Status bar is selected, those drawings that where assembled
will appear first, followed by a line separator and then the
remaining drawings.
Openings will not Extract if SoftView Flag is
Unchecked
In Version 12, any wall that has their
SoftView Flag unchecked will not have their opening generate in
SoftView.
- Edit a wall that has openings in
it.
- Uncheck the SoftView box near the
bottom of the menu.
- Generate an elevation on that
wall.
Fit Top of Wall to Roof Automatically Removes Gable End
Material
In a situation where there is a wall
underneath a gable roof edge, there are two options which to select to
provide the gable area wall. When a gable roof edge is placed, it
automatically places a gable end provided by the roof. This is desired if
the gable area wall were to be framed separately from the wall below. The
other option is to edit the wall below to fit to top of roof, which
balloon frames the wall to fit up into the gable area.
In Version 12 edit the gable end wall
and press the button for “Fit top of wall to Roof”. The gable end material
will automatically be turned off in Roof mode. Pressing the Go button will
show the wall filling the gable area above and the wall at Multi-Height
and the Rake option is now enabled.
Generated Drawings Use Highest Drawing
Configurations
Drawings generated from SoftView will
use the Drawing Configurations from the highest drawing on the Assemble
Floors list. In previous versions of SoftPlan, these generated drawings
would receive their Drawing Configurations from the System level.
would include Character Setup, Color assignments, Material Dimensions, Walls
and Beams, etc.
| This ensures a
higher level consistency throughout a set of drawings as any options set in the
original drawing will automatically be transferred to the generated
drawing. |
Ceiling Joist and Floor Joist Have Separate Display
Properties
Within SoftView, the display options
for ceiling and floor joist have been separated to give greater control to
the user. Now a detailed rendering of exposed ceiling structure can be
generating, without the overhead of having the hidden floor joists also
generating, or in the case of a basement, the exposed floor joist can be
viewed, while a main floor ceiling joist layout remains off.
- Within SoftPlan, Select Build >
Assemble Floors > Add the floor plans in the order the are to be
vertically stacked.
- Select Build > 3D > and the
mode to generate.
- On the Extraction Options menu, place
a checkmark next to Framing
- Within SoftView Select Material >
Structure.
- Double click on the display box to
the corresponding item to enable or disable is visibility.
Solids use appropriate texture mapping type Planer, Cubical,
Spherical ...
Solids in SoftView now
have the ability to use appropriate texture mapping type,
Planer, Spherical, and Cylindrical, when generating a
Rendered view in 3D. This will allow the texture to appear
properly on the Solid.
- In a drawing, from
the Solids menu, draw a Cylinder, a Plane, and a Sphere
and save it.
- Generate a Rendered
3d on the drawing.
- In 3D, click on
Material Option at the top of the screen and select a
texture for each Solid. In the Texture Map Type section,
select the appropriate type for the Solid.
Walk Through Added
ability to now perform a “walk-through” while working within Softview.
This added feature utilizes your keyboard functions to complete the task,
and was unavailable in previous versions of Softplan. In order to be
able to take advantage of this feature, you must be in the Softview 3D
module.
With your 3D image visible,
select the one of the Up, Down, Left, or Right Arrow keys on your
keyboard.
Without having to select GO,
the view of your image will automatically regenerate based on the
following: ·Up Arrow – Move Forward
·Down Arrow – Move Backward
·Left Arrow – Turn Left
·Right Arrow – Turn Right
Along with the Arrow keys on
your keyboard, you can use the Ctrl, Shift, Alt, and / (forward
slash), keys to help perform specific tasks.
press the Shift key while at the same time pressing one of the Up,
Down, Left, or Right Arrow keys on your keyboard.
Again, without having to
select GO, the view of your image will automatically regenerate
based on the following:
·Shift + Up Arrow – Move Up
·Shift + Down Arrow – Move Down
·Shift + Left Arrow – Move Left
·Shift + Right Arrow – Move Right
- The remaining keyboard functions will
perform the following tasks:
·Ctrl + Up Arrow – Move Up
·Ctrl + Down Arrow – Move Down
·Alt + Any combination of selected keys – “Run” (Speeds up the Walk-Through
process)
·/ (forward slash) – Look Forward (Center camera)
SoftView Image Preview Window
SoftPlan Version 12 has added a
Preview Window feature while using the SoftView 3D module. The feature
allows you to view a preview of your image, if the camera position has
been moved, materials textures modified, or items added or removed,
without having to regenerate the image completely. In order to demonstrate
this feature you must be in the SoftView 3D module.
From the pull
down menus select Camera. The Camera Control window will
open.
Move the camera into its new
position respectively. Before selecting the OK button, select the
preview button in the lower right-hand corner.
then expand to the right, displaying a preview of the image,
referencing any changes that you have made to the image. You can
then continue to modify the image as required, or exit the Camera
Control window and regenerate the image.
Animations can be Saved to AVI Files
SoftPlan’s 3 Dimension program now in
includes the capability of creating an animation file in an AVI format.
This allows an animation of a 3-Dimensional model to be viewed by a
client.
Once the model is generated to the
screen, the steps are as follows:
Note : Within SoftView the 3D
model must first be in Rendered mode.
- Select Options > Output
Options.
- Select to Create
Animation.
- Select the
Animation Path. Note that there are two options: to rotate the camera around
the focus point, or to rotate the focus point around the
camera.
- You must select
the total frames which will be used when creating the animation. The greater
the number of frames, the smoother the animation will appear. However, more
frames will take longer to generate, and the resulting file will be
larger.
- On the output to
file, set the Image Size that will be used for the AVI file.
Within the
Animation File Options the following settings can be set:
- Set the
Frames/Second based on how many frames per second will be played during
the generated AVI file (the greater the number, the smoother the
animation).
- Set the
color depth to be used. Note the greater the number the greater the
color palette to be used, but the longer it will during the creation of
the AVI file.
- Select OK
followed by Go.
- Within the
Save As menu, type the file name. SoftPlan will automatically save the
file as a SoftPlan Animation (*.avi) file.
- Select
Save and SoftView will now render each frame needed to create an
animation based on the animation path selected (see step
3).
- Once saved, this
AVI file can be viewed using most media players. The viewer does not need to
own SoftPlan to watch the animation.
Openings in the Background of Saved Sections are Formed into
Elevation Openings
Version 12 now allows Openings in the
background of saved Sections to be formed into Elevation Openings. This
allows easier manipulation of the opening. Previous versions of SoftPlan
created these openings as lines.
- Generate a Cross Section. Background
must be enabled for the Openings to be generated. Be sure that the
section lines are oriented to that they will allow openings to be
generated.
- Save the Cross Section and exit
SoftView.
- Load the saved drawing. The Openings
are saved as Elevation Openings.
Note: Some window treatments, such
as Trim, Shutters, etc, will cause the openings to be saved as
shapes.
Quality of Shaded and Textured Mode Images Improved
SoftPlan version 12 has improved upon
the quality of 3-D images produced by either the Shaded or Textured Modes
within SoftView. Shaded mode generates an image with shaded surfaces and
can be useful for determining depth and space planning. Textured mode
generates an image with photographic bitmap textures applied to the
surfaces, useful for the comparison of surface materials. Version 12 has
improved on the quality of the images produced in these two modes by
allowing a Background Image to be set. Previously a Background Image could
only be set in Rendered Mode. Textured mode will also allow for
Transparencies, allowing for Rendering Trees and Shrubs to appear more
realistically. SoftPlan version 12 has further improved the quality these
two modes through the use the OpenGL graphics engine.
Textured mode is the highest quality
image that SoftPlan Lite can generate.
Elevations and Sections Always Generate at 100%
SoftPlan Version12 has improved the
initial view of Elevations and Section by ensuring that they will always
generate in a full window. SoftView has a scaling option that allows a
3-Dimensional view to be scaled down by specific percentages. In previous
versions, if 3D view was set to be scaled less than 100% and an Elevation
or Section was generated after the 3D, the Elevation or Section would
generate in the same scale. The Scale feature is not accessible in
Elevation or Section, so there was no direct way of rescaling the image.
Now, Elevations and Section will always generate at 100% full scale
regardless of the scale set in the previous 3D view.
- Open an existing house plan and
select Build > Assemble Floors and assemble the floor plans from the
lowest drawing to the highest.
- Select Build > 3-Dimension >
Rendered. Select OK at the Extraction Options menu.
- From within SoftView – 3D, select
Window > Scale > 100% and then select the GO button to Render the
image in a scaled Window.
- Select File > Exit to exit the 3D
view, saving all changes.
- Back in SoftPlan select File >
Build > Elevation and select to view the Front Elevation. The
Elevation will open at 100% scale.
Animations, Rotate Camera Around Focus and Focus Around Camera
Added
while positioning the camera in SoftView. SoftPlan Version 12 has added a
new feature in SoftView 3D that allows the 3D model of the floor plans to
be animated. The valuable new tool, which was previously unavailable, can
be used to animate the floor plans in one of two animation paths. First,
the Camera can be set to rotate around the Focus to get a view from the
outside of the plan. This simulates a walk-around of the building with
the focus always on the house. The second animation path is to rotate the
Focus around the Camera to allow a full 360 degree view from the inside
of the plan. This simulates the action of turning around in a stationary
spot to get a view of an entire room. In both animation paths, the Total
Frames can be set, and the direction the Focus or Camera moves in can be
reversed. In addition, the animation can be displayed directly to the
screen, or an Animation File can be created and saved and played at a
later time. This tremendous new tool will greatly benefit in selling the
design to perspective clients.
- Open a completed house design in
SoftPlan.
- Select Build – Assemble Floor and
stack the drawings from the lowest floor plan to the highest.
- Once OK is selected on the Assemble
Floors dialog, the Build menu will automatically open again. Select
3-Dimensions.
- Animations can be made with any 3D
Mode (Wire Frame to Rendered). Select a Mode depending on the quality of
the animation you want.
- Select OK on the Extraction Options
dialog
- In SoftView 3D select Camera to open
the Camera Control. Move the Camera and Focus to a desired
position.
- Select Options – Output
Options.
- Select the Create Animation radio
button.
- Specify the Animation Path and Total
Frames you want for the animation. Close the dialog by selecting the OK
button.
- Selecting the GO button will then
animate the model on screen according to the current location of the
Camera and Focus.
Move of a Roof in Softview Blocked
Move of a roof in Softview has been
prevented in V12. This will prevent misalignment of the roof if it has
been selected.
If the Move command has been selected,
clicking on the roof will not select or show any change.
1. Generate an Elevation.
2. While in SoftView, select the Move command.
3. Click on the Roof, nothing should happen.
