Corner of Opening Frames Locatable by Snap
SoftPlan Version 12 has added opening
frame corners to the list of locatable snap points. You can now snap the
cursor to any corner of an opening frame to help is aligning items to the
edge of the opening frame, such as drawing an arc to indicate a roundtop
transom above a window
Walls in Site Mode can be Located via Snap
Site Mode in Version 12 now allows
Walls to be located via the Snap command. Snap is useful to place items
quickly and accurately on the drawing.
- In a floor plan drawing, go into site
mode, select an item to draw, such as a gas line.
- Click on the Snap icon in the
toolbar.
- Place your cursor near a wall and
click the mouse. The cursor will snap to the wall.
