Auto-Cabinet-Automatically-Skips-Any-Symbols-Along-the-Run.html
v14features_SoftView_3Dimport1.htm
v14features_SoftView_3Dimport.htm
v14features_paint_tiff_png.htm
v14features_print_project_info.htm
v14features_print_scale.htm
v14features_posts_newcolumns.htm
Back | Print Deck Videos [SUBPAGE_BULLET_LINKS] Back | Print
3D.html
Back | Print
3d_support_FAQ.html
Back | Print
3D-Rendering_class.html
3D-Rendering.html
Back | Print Back | Print
A-custom-symbol-I-created-is-not-listing-when-I-generate-a-report.-What-should-I-do-to-have-it-list.html
A-note-that-I-have-added-to-my-drawing-and-assigned-a-cost-to.html
A-short-sample-from-an-online-Intermediate-training-class.html
v14features_building_options_lock.htm
v14features_layers_lock.htm
Ability-to-Lock-Layers-and-Building-Options.html
v14features_edit_access.htm
Activation-Code-No-Result.html
Activator-Driver.html
v14features_SoftList_banner.htm
Add-Companion-Material.html
v14features_SoftList_companion.htm
Add-Detail-to-a-Kitchen.html
v14features_drawing_end_panel.htm
Add-False-Dormer.html
v14features_wall_framing_add.htm
Add-on-Modules.html
Add-Roof-Edges.html
Add-Roof-Edges.html
Add-Shed-Roof.html
Add-SoftPlan-to-your-address-book.html
v14features_building_options_type_erase.htm
Adding-Detail-to-a-Kitchen.html
Adding-Electrical-Layout.html
Adding-Light-to-a-Model-Movie.html
Adding-Windows-&-Doors.html
Adding-Windows-and-Doors.html
v14features_electrical_icons.htm
v14features_roof_curved.htm
v14features_posts_adjust.htm
Adjust-of-Cabinet-Run.html
v14features_tools_adjust.htm
After-applying-the.html
After-changing-the-heights-of-my-walls-and-regenerating-the-elevation-or-3D-the-roof-is-no-longer-referencing-the-walls-correctly.-How-do-I-fix-t.html
After-I-upgraded-my-SoftTalk-does-not-work.html
After-using-Roof-On-Opening-to-draw-a-roof-over-a-window-the-gutter-from-the-main-roof-still-shows-up-in-the-elevation.html
Allow-Countertop-Property-on-Symbol.html
v14features_SoftView_alpha_map.htm
An-exported-multi-drawing-(.DWG-or.DXF)-appears-as-separate-drawings-when-opened-in-AutoCAD;-what-can-be-done-to-make-it-appear-as-it-does-on-Sof.html
v14features_posts_anchor.htm
v14features_cross_section_angled.htm
v14features_roof_apply_gable.htm
v14features_paint_arc_cords.htm
v14features_opening_arch.htm
Back | Print
Architect.html
v14features_system_options_archive.htm
Are-there-any-other-examples-to-help-learn-the-Roof-Tools.html
Are-there-instructions-to-help-install-the-new-SoftPlan-Educational-software-I-just-received.html
Area @Area Print Command Added to Automatically Print the Requested Area By simply adding a SoftPlan Information Stamp as a Note to the drawing, the corresponding...
v13features_area.htm
Areas can Reference the Inside, Outside, or Outermost Bearing Edge of a Wall SoftPlan Version 12 has added the ability to now select which edge an area is to reference. In previous versions this was...
TMP6gwr38o7i0.htm
home design software
Residential Design Software for Professionals
Designing with SoftPlan offers practical tools that are simple to learn and easy to use.
With more than two decades of development. SoftPlan offers a unique and industry leading solution for residential and light commercial design. Maximum automation combines with a short learning curve to create unlimited design possibilities. SoftPlan allows you to build a model of your project before you build it on the site, and your "virtual model" provides complete construction documents, 3D renderings, and accurate material list, and cost estimate reports.
The most advanced residential design software and the only one with free technical support and no annual user fees.
Working Drawings 3D Renderings Material Lists
SoftPlan Version 14 is a huge hit … SoftPlan gives me control of the 3D model which is something not easily done in AutoCAD®. SoftPlan Version 14 is very content rich, in fact the best I have seen from any program.
2012_Area.html
Back | Print
Area.html
Area Area Exclude Rectangle Command Added Area Exclude options have been added to Area Mode. Using an exlude command allows sections of an enclosed area to be excluded from the...
v14features_area.htm
v14features_cabinets_area.htm
v14features_area_rectangle.htm
Area-Movie.html
Area-How-to-Draw-and-Edit-Areas.html
Areas.html
v14features_SoftView_assemble.htm
v14features_site_assign_color.htm
Assigning-an-Icon-to-a-Library-Item.html
v14features_roof_framing_attic.htm
v14features_symbols_attribute.htm
Attribute-Fields-Added-to-Symbols.html
Auto-Cabinet-Function-Added.html
Auto-Dimension-Command-Information-Popup.html
Auto-Extension-&-Dimension.html
v14features_SoftView_auto_horizon.htm
v14features_roof_auto_multi.htm
Back | Print
AutoCAD-User.html
Automatic-Cross-Sections.html
Automatic-Elevation.html
Automatic-Elevations.html
v14features_stairs_label.htm
Automatic-Roof.html
v14features_SoftView_background.htm
v14features_misc_banding.htm
v14features_walls_banding.htm
v14features_walls_banding_profile.htm
v14features_opening_baseboard.htm
Basement-Creation.html
v14features_reView_batch_export.htm
Bathroom-Layout.html
Beam-End-Profiles.html
v14features_beams_length.htm
v14features_SoftList_beam_offset.htm
2012_Beams.html
Beam Pocket Depth Automatically Adjusts to Wall Width Version 12 of SoftPlan has improved how Beams set themselves in walls. A beam pocket is automatically created when a beam intersect a wall. The...
beam_pocketdepth.htm
Beams.html
Beams Beam End Profile The beam end style can be specified in edit beam end style, in addition to the Plumb and Rake settings with the ability to set the profile through...
v14features_beams.htm
Beams.html
Beam_Video_Library.html
v14features_beams_roofmode2.htm
v14features_beams_roofmode.htm
v14features_beams_roofmode1.htm
v14features_beams_ext.htm
Block-Commands-Such-as-Move-Are-Not-Interrupted-by-Zoom.html
v14features_edit_block_form.htm
v14features_wall_framing_rake.htm
Bonus-Content.html
v14features_opening_bottom.htm
Back | Print
Builder.html
2012_Building-Options.html
Building Options Ability to Lock Added A Lock selection is available on the Building Options dialogs. Items assigned to the Building Option cannot be erased...
v14features_building_options.htm
v14features_SoftList_BuildSoft_AU.htm
v14features_SoftList_BuildSoft_export.htm
v14features_room_butler.htm
Cabinet-Layout.html
Cabinet-Layout-in-3D.html
Cabinet-Layout-in-3D-How-to-Modify-a-Cabinet-Layout-in-SoftView-3D.html
Cabinet-Layout-How-to-Quickly-Assemble-a-Kitchen-Design-Using-SoftPlan's-Various-Cabinets-Commands.html
Cabinet-Text-Can-Be-Relocated-with-the-Move-Command.html
Cabinets Auto Cabinet Automatically "Skips" Any Symbols Along the Run With this method, Symbols would first be drawn (dishwasher, range, trash...
v13features_cabinets.htm
Cabinets.html
Cabinets Adjust of Cabinet Run Allowed Watch Movie Allow Countertop Property Added to Symbol When seleted, a run of...
v14features_cabinets.htm
2012_Cabinets.html
Placement of Cabinets Next to Each Other Improved Version 12 has improved the program's ability to automatically place one cabinet next to another. When you draw a cabinet along a wall, the back of...
cabinets_placement.htm
Back | Print
Cabinets_support_FAQ.html
Cabinets-Can-Be-Changed-to-Symbols.html
v14features_cabinets_different_height.htm
Calculate-Roof-Edge-Height.html
Can-a-drawing-created-in-AutoCAD-be-imported-into-SoftPlan.html
Can-a-JPEG-(.jpg)-texture-file-be-imported-into-SoftPlan.html
Can-AutoCAD-open-a-SoftPlan-drawing.html
Can-I-add-my-custom-walls-from-an-older-version-without-recreating-them.html
Can-I-bring-only-my-system-settings-from-an-earlier-version-of-SoftPlan-into-my-current-SoftPlan-install.html
Can-I-change-my-mouse-clicks-back-to-the-Version-11-mouse-settings-using-From-and-To.html
Can-I-eliminate-the-need-to-have-the-Version-10-key-installed-in-order-to-open-Version-10-and-earlier-drawings-in-the-newer-Version.html
Can-I-exchange-my-beige-parallel-port-key-for-a-USB-key-I-am-a-Version-13-user.html
Can-I-have-multiple-keys-on-the-same-parallel-port.html
Can-I-import-drawings-from-a-newer-version-of-SoftPlan-to-an-older-version.html
Can-I-install-my-new-SoftPlan-Version-on-my-computer-and-still-use-the-old-SoftPlan-Version.html
Can-I-Scan-Drawings-Into-SoftPlan.html
Can-I-use-Microsoft-Remote-Desktop-to-access-SoftPlan-from-another-computer.html
Can-I-use-the-Calculator-to-accept-input-for-the-Pitch-measurement.html
Can-SoftPlan-print-to-a-larger-format-plotter.html
Can-the-distance-a-beam-projects-out-into-a-wall-be-controlled.html
Can-the-Floating-toolbar-be-modified.html
Can-the-Material-Costing-defaults-be-changed.html
Can-the-waste-factor-be-manually-changed-for-individual-items-within-SoftList.html
Can-upgrades-be-purchased-on-installments.html
v14features_openings_case.htm
New Entries Added to Ceiling Finishes Softplan Version 12 offers further flexibility for the ceiling finishes than ever before. Previously, ceiling finishes were limited to 4 predefined choices,...
ceiling_finishes.htm
v14features_SoftList_ceiling_stair.htm
v14features_stairs_finish.htm
Ceilings Ceilings Included When Drawing Rooms in Room Mode Dimensions and Extensions Can Be Added in Ceiling...
v14features_ceilings.htm
2012_Ceilings.html
Back | Print
Ceilings.html
Ceilings Area is Reported on a Ceiling Edit Simply Edit the Ceiling drawn in Ceiling mode to display the area. This is useful in determining Heat Loss and Gain...
v13features_ceilings.htm
v14features_room_ceiling.htm
v14features_ceiling_room_mode.htm
v14features_SoftView_center_focus.htm
v14features_symbols_chair.htm
Chamfer.html
v14features_decks_champher.htm
v14features_decks_champer.htm
Change-of-Address.html
Change-of-Address-Success.html
Change-Symbol.html
Change-Wall-command-does-not-change-the-wall-heights.-How-do-I-correctly-accomplish-this.html
Back | Print
Chapter-22.html
Back | Print
Chapter-5.html
Back | Print
Chapter-6.html
Back | Print
Chapter-9.html
Cleanup-is-not-removing-portion-of-walls-that-bisect-with-one-another-How-do-I-change-this.html
v14features_floorsystem_cleat.htm
Closet-Rod-and-Shelf.html
Collinear-and-Near-Collinear-Walls.html
v14features_opening_colonial.htm
Color Cursor Color Configuration Added The assigned colors menu gives the ability to change the setting for the cursor to your own preference. When the color is...
v13features_color.htm
v14features_color.htm
Non-Printing Items Now Have a Color Selection A new color selection has been added to the Assign Color option in System/Drawing Options. Construction Color is now used to control items that do not...
color_constcolor.htm
v14features_roof_planes_color.htm
v14features_SoftList_color.htm
Back | Print
Commands.html
Company-Information.html
Complex-Roof.html
v14features_electrical_connection.htm
Contact-Us.html
Copy Group Is Available as a Selection Item to Allow Groups of Items to Be Copied When the Copy command is used, the Group option can be selected in the...
v13features_copy.htm
2012_Copy.html
Copy Select Move Point Option Added to Copy Block This feature will allow the selection of an exact point as a "handle" for the copy. ...
v14features_copy.htm
Copy-Item-SoftView.html
v14features_openings_corner_blocks.htm
v14features_walls_corner_board.htm
Countertop-Command-Added.html
v14features_cabinets_countertop.htm
v14features_cabinets_ajacent.htm
v14features_cabinets_linestyle.htm
v14features_SoftList_freeform.htm
v14features_walls_cover.htm
v14features_floorsystems_cover.htm
Cross Section Cut Lines Can Be Added to any Drawing in the Assemble Floors List A section line can be placed on any floor in the assembled floors list. A cross...
v14features_cross_section.htm
Cross Section Angled Cross Section Lines Added This can be used in plans where the cross section will not be strictly horizontal or vertical. Often in plans with...
v13features_cross_section.htm
2012_Cross-Section.html
Cross-Section-Movie.html
Cross-Sections.html
Back | Print
Cross-Sections_support_FAQ.html
Currently-the-Area-Command-Cleans-Up-to-the-Outside-of-a-Wall-How-Can-I-Change-to-Outside-of-a-Stud.html
v14features_wall_curved3D.htm
Custom-Deck-Rail.html
Customize-Symbol-Libraries.html
v14features_symbols_cuts_countertop.htm
Deck-Design.html
Deck-Design-How-to-Add-and-Modify-Rails.html
Deck-Design-How-to-Add-Mitered-Deck-Boards.html
Deck-Design-How-to-Draw-and-Modify-Various-Components-of-a-Deck-Layout.html
v14features_floorsystem_deck_framing.htm
v14features_decks_shaped.htm
Deck-Outline.html
v14features_decks_stairs.htm
Decks Deck Beam Selection Dialog Made Larger to Display More Walls at Once The dialog where a deck beam is selected to draw will now display with a longer listing....
v13features_decks.htm
Decks.html
Deck Edges Formed by Break Sections Improved SoftPlan version 12 has improved upon the Break Section tool for Decks. This tool allows for additional edges to be created from an existing deck shape,...
deck_edges.htm
Decks Champher Option Added The champher option has been added to decking. Using champher creates a more realistic 3D view. Watch Movie Deck Joists Can Have...
v14features_decks.htm
2012_Feature_Decks.html
Decks-2012-Demo.html
v14features_layers_default.htm
v14features_building_options_default.htm
Defining-a-Wall.html
v14features_walls_definition.htm
v14features_railings_deflection.htm
Home Design Software Demo
Home Design Software Trial
Demonstration.html
v14features_SoftList_description.htm
Design-a-Deck.html
SoftPlan is a better solution for Residential Designers because:
Residential Designers create a large portion of the home designs built in North America every year and represent a large portion of the SoftPlan user base. These professionals focus solely on residential design and are typically very small businesses with many being sole proprietorships.
Time and productivity are particularly important to these small firms and as a result SoftPlan is a perfect choice. In the past these firms typically created drawings either by hand or with AutoCAD®. SoftPlan represents a significant productivity upgrade over both and at a lower cost than AutoCAD®.
In addition to being a great value and fast, SoftPlan is also easy to learn and a pleasure to use as you will feel that you can finally design freely without letting the technology hold you back. See for yourself why so many designers have made the switch to SoftPlan.
Designer.html
Designing-Cabinets.html
Detailing-Elevations.html
Detailing-Sections.html
Details-Symbols.html
v14features_symbols_details_symbols1.htm
Difference.html
v14features_tools_difference.htm
Extensions Do Not Pull From Items if Their Visibility is Off Version 12 has improved Extensions so that they will not pull off of objects if their Visibility option has been turned off. In SoftPlan,...
dimen_extenvis.htm
v14features_roof_extension_double.htm
Dimension-changes-are-not-being-accepted.-How-do-I-correct-this.html
Dimension-Numbers-Are-Automatically-Placed-to-Avoid-Other-Items.html
v14features_dimensions_extensions_avoid.htm
Dimension-Numbers-Update-as-Items-Are-Moved.html
v14features_dimensions_extensions_reset.htm
v14features_dimensions_extensions_point.htm
Dimensioning-the-Plan.html
Dimensioning-with-SoftPlan.html
Dimensions.html
Dimensions.html
Back | Print
Dimensions_support_FAQ.html
Dimensions & Extensions Auto Dimension Added to Default Toolbar The auto dimension icon is now available in the dimension icons group on the default tool bar. ...
v14features_dimensions_extensions.htm
Dimensions & Extensions Auto Dimension Interior Walls Option Added to Auto Dimension ‘Auto Dimension Interior’ walls has been added to the Dimension Options....
v13features_dimensions_extensions.htm
2012_Dimensions-&-Extensions.html
Dimensions-and-Extensions.html
v14features_roof_framing_dim_ext.htm
v14features_symbols_dining.htm
v14features_visible_items_print_pen.htm
Display-Print-Pen-Styles-Building-Options.html
v14features_SoftView_silhouette_render.htm
Distance.html
v14features_SoftView_distance.htm
Do-I-have-to-assign-a-texture-for-each-cabinet.html
Do-I-need-to-draw-a-ceiling-board-if-SoftList-&-3D-are-not-important-to-me.html
Do-I-place-the-sill-plate-on-the-foundation-or-main-floor-plan.html
Do-I-trace-hole-before-or-after-adding-an-intersecting-roof-section.html
Does SoftPlan charge for technical support?
Does-SoftPlan-charge-for-technical-support.html
Does-SoftPlan-contain-manufacturers-catalogs.html
Does SoftPlan have a trial version?
Does-SoftPlan-have-a-trial-version.html
Does SoftPlan have an user's forum available online?
Does-SoftPlan-have-an-User's-Forum-available-online.html
Does Softplan have home design software for mac?
Does-SoftPlan-have-home-design-software-for-mac.html
Does-SoftPlan-include-a-printed-manual.html
Does SoftPlan require a user to pay an annual support fee?
Does-SoftPlan-require-a-user-to-pay-an-annual-support-fee.html
Does-the-Registration-Key-need-to-be-plugged-in.html
Does-the-stair-tread-depth-include-the-nosing-depth.html
v14features_roof_dominate.htm
v14features_cabinets_doors_removed.htm
v14features_opening_double_entry.htm
v14features_electrical_double.htm
2012_Draw.html
v14features_SoftView_draw_opening.htm
Draw-Profile-Command-Added-to-SoftView.html
v14features_roof_plane.htm
Draw-Select-Will-Select-Individual-Studs.html
v14features_symbols_plane.htm
Drawing Keyboard Shortcuts are User Definable and Can Be Assigned to Any Command SoftPlan comes with a series of predefined keyboard shortcuts to quickly access...
v13features_drawing.htm
Drawing Add End Panel Option Added to Rod & Shelf Drawings in Memory Are Indicated With a Graphic Icon...
v14features_drawing.htm
Floating Toolbar Activated Exclusively via Double Right Mouse Click Version 12 has specific settings for the mouse button operations. Exclusively, in Version 12 the double right mouse click activates...
drawing_floatingtoolbar.htm
Back | Print
Drawing-Management.html
v14features_drawing_memory.htm
Driver-Updates.html
During-installation-I'm-prompted-with-this-disk-contains-data-formatted-in-the-MS-Joliet-system.-What-should-I-do.html
v14features_roof_dutch_dimension.htm
v14features_roof_dutch_different.htm
v14features_roof_dutch_improved.htm
v14features_reView_dwg_export.htm
v14features_SoftView_export.htm
2012_Edit.html
Edit Change Symbol Command Added The Change Symbol command can be used to replace all instances of an existing symbol type to a new symbol. For instance, all oval...
v13features_edit.htm
Edit Access to Wall and Beam Definition Added to Wall and Beam Edit Dialog Answer to the "Align" Question on...
v14features_edit.htm
v14features_SoftList_spreadsheet.htm
v14features_roof_edit_edge.htm
Editing-Windows-&-Doors.html
SoftPlan home design software Educationial program frequently asked questions.
Educational.html
v14features_drawing_time.htm
v14features_electrical_meter.htm
Electrical 4 Way Switch Added An addition has been made to the Electrical Symbols to include a standard 4-way switch. ...
v13features_electrical.htm
Electrical Legend Configuration SoftPlan Version 12 has added the ability to now configure your Electrical Legend, much like configuring an opening legend. You now have the option to specify which...
elect_legend.htm
Back | Print
Electrical_support_FAQ.html
Electrical Additionial Electrical Icons Added to the Toolbar This allows more library items to be assigned shortcuts on the toolbar ...
v14features_electrical.htm
Electrical.html
2012_Feature_Electrical.html
Electrical-Adding-Electrical.html
Electrical-2012-Demo.html
2012_Elevation.html
Elevation Sun Studies Can Be Completed in Elevation Save Elevations, Sections, and Roof Plans Has an Option...
v14features_elevation.htm
Elevation-has-generated-with-the-second-floor-beneath-the-main-floor.html
v14features_opening_elevation_trim.htm
Elevations-and-Cross-Sections.html
Elevations-Movie.html
v14features_opening_multi_radi.htm
v14features_SoftList_end_page.htm
v14features_beams_end_style.htm
SoftPlan now lets you integrate your projects into REScheck™ — The Department of Energy’s Building Energy Codes Program. REScheck™ reports are quickly becoming standard in permit requirements and can cost between $200 and $700. Let SoftPlan streamline the permit process by creating the REScheck™ report based on the plans you have already created.
Just a couple clicks of the mouse will give you a full report. It’s quick, and easy. And SoftPlan’s direct integration with REScheck™ will not only save you money but the feedback that you receive from the REScheck™ report will help you achieve a more energy efficient product.
Energy-Compliance.html
v14features_symbols_columns.htm
v14features_symbols_car.htm
Enhanced-Symbol-Libraries.html
v14features_symbols_bed.htm
v14features_SoftView_texture.htm
v14features_symbols_enhanced_trees.htm
Equal-Post-Spacing-How-to-Use-the-Divide-Segments-Feature-to-Equally-Space-Posts.html
Equally-Spaced-Openings.html
Cross Erase Command Added Version 12 has an additional command the added command for Cross Erase. This command can be used to erase items using a selection trace. Go to Erase > Cross Erase Use the...
Erase_crosserase.htm
Erase Items Must Be at Least Partially on Screen to Be Erased This will prevent the property lines from being removed when erasing other items when zoomed in on a...
v14features_erase.htm
v14features_SoftList_export_html.htm
Export-to-QuickBooks.html
Back | Print
Extended-Wall-List.html
v14features_dimensions_extensions_start.htm
v14features_floorsystem_dimension.htm
Exterior-3d.html
v14features_openings_slide.htm
v14features_roof_false_gables.htm
FAQs.html
v14features_roof_framing_clip.htm
File DWG and DXF Export of a SoftView Model Can Include Textures DWG AutoCAD® 2007 Files Import DWG/DXF Export...
v14features_file.htm
File>Open will Open a DXF/DWG as a SoftPlan Drawing SoftPlan Version 12 has changed the way DXF and DWG files can be opened. When a DWG or a DXF file is selected from the Open dialog, SoftPlan...
file_open.htm
2012_File.html
v14features_reView_room_mode.htm
v14features_room_fill.htm
Finishing-a-Room.html
v14features_print_fit_overlay.htm
v14features_beams_fit_roof.htm
v14features_roof_fit_gable.htm
v14features_walls_fit_stair.htm
v14features_electrical_hip.htm
Floor-Joist.html
Cross Section Groups Floor Joists Together in Joist Sections Floor Joists in a generated cross section are grouped together into a Joist Section. This will make it easier to modify the Cross Section....
floor_joistsection.htm
Floor System Cleat Command Added This new command places a Cleat or Plate on top of floor joist to support roof framing. This is useful for designs...
v14features_floorsystem.htm
Floor System Beams Added to Floor System Will Allow for the Creation of “Flush Beams” When drawing Beams in Floor System mode, they will draw flush, with the bottom...
v13features_floorsystem.htm
2012_Floor-System.html
Floor-System-Movie.html
Back | Print
Floor-Systems_support_FAQ.html
Floor-Systems.html
Form-Solid-Polygon.html
v14features_wall_framing_options.htm
v14features_notes_framing.htm
v14features_visible_items_framing.htm
v14features_SoftList_frieze_group.htm
v14features_SoftList_frieze_style.htm
Gable-Style-is-Automatically-Added-to-Any-Roof-Placed-on-a-Multi-Height-Wall-Via-Auto.html
v14features_roof_gable_vent.htm
Back | Print
General.html
Generated-Grade-Lines.html
v14features_site_grade_line.htm
v14features_SoftList_variables.htm
v14features_misc_glulam.htm
v14features_SoftView_go_room.htm
v14features_openings_grille.htm
v14features_SoftList_cabinet_face.htm
Group-Is-Available-as-a-Selection-Item-to-Allow-Groups-of-Items-to-Be-Copied.html
v14features_SoftList_stair_stringer.htm
v14features_SoftList_wall_radius.htm
v14features_roof_fascia_gutter.htm
v14features_SoftList_header.htm
v14features_wall_framing_header.htm
v14features_stairs_hidden.htm
v14features_stairs_hidden_option.htm
v14features_symbols_high_surface_trees.htm
v14features_SoftView_highlight.htm
v14features_SoftList_highlight.htm
Hold-Position-Option-Added-to-Paste-from-SoftPlan-Clipboard.html
Home-Design-Software-Products.html
Home-Design-Software-Solutions.html
How-can-I-add-a-degree-sign-or-a-diameter-symbol-to-a-note.html
How-can-I-add-or-delete-lines-on-the-Roof-plan.html
How-can-I-balloon-frame-a-gable-end.html
How-can-I-bring-a-SoftPlan-drawing-into-Microsoft-Word.html
How-can-I-combine-more-than-one-drawing-on-one-sheet-and-set-the-drawings-at-different-scales.html
How-can-I-control-the-visibility-of-my-electrical-symbols-in-Drawing-mode.html
How-Can-I-Convert-a-Floor-Plan-From-an-Imported-Dxf-Dwg-File-Into-a-Softplan-Floorplan.html
How-can-I-create-a-fireplace-with-a-chimney-for-SoftView-(3D.html
How-Can-I-Display-the-Room-Size.html
How-can-I-do-a-real-time-walkthrough.html
How-can-I-draw-a-1-2-round-window-on-top-of-another-window.html
How-can-I-draw-a-section-line-to-include-a-jog.html
How-can-I-generate-a-3D-image-that-is-crisper-on-the-edges.html
How-can-I-generate-a-bird's-eye-view-and-also-display-the-bearing-walls-beneath.html
How-can-I-hang-my-floor-joists-so-that-the-tops-of-the-joists-are-equal-with-the-top-of-the-sill-plate.html
How-can-I-have-SoftList-list-my-garage-walls-as-having-a-pressure-treated-bottom-plate.html
How-can-I-import-my-own-trees-or-other-images-into-3D.html
How-can-I-Orbit-in-SoftView.html
How-can-I-place-a-square-roof-over-a-bay-window-area.html
How-can-I-put-all-of-my-elevations-on-one-sheet-for-plotting.html
How-can-I-remove-the-cabinet-names.html
How-can-I-reset-my-Report-Configurations-to-the-way-they-were-shipped.html
How-Can-I-See-SoftPlan.html
How-can-I-show-and-print-a-wall-which-is-to-be-removed-as-dashed.html
How-do-I-add-a-double-Sill-Plate.html
How-do-I-add-custom-grilles-like-prairie-style-grilles-to-an-opening.html
How-do-I-add-depth-to-my-3D-rendering.html
How-do-I-add-dimensions-to-the-roof-framing-plan.html
How-do-I-add-notes-to-a-floor-joist-layout.html
How-do-I-add-texture-to-the-elevation.html
How-do-I-adjust-individual-joists-once-the-entire-set-has-been-drawn-in.html
How-do-I-backup-drawings.html
How-do-I-break-a-wall.html
How-Do-I-Calculate-the-Area-of-My-Site-Plan.html
How-Do-I-Change-My-Settings-So-That-the-Area-Calculates-to-the-Outside-of-My-Bearing-Wall.html
How-do-I-change-SoftList-so-that-my-precuts-list-out-as-92-5-8'.html
How-Do-I-Change-the-Background-Color-On-the-Exported-Review-Files.html
How-do-I-change-the-orientation-of-a-Joist-Poly.html
How-do-I-change-the-plan-view-of-a-wall-to-print-with-a-grey-tone-fill.html
How-do-I-change-the-roof-framing-spacing-from-16-to-24.html
How-do-I-change-the-size-of-text-being-used-for-Opening-Dimensions.html
How-do-I-change-the-size-of-text-being-used-for-various-note-types.html
How-do-I-change-the-walls-to-display-with-a-shaded-texture-as-well-as-print-the-walls-with-this-shade.html
How-do-I-check-for-updates.html
How-do-I-combine-several-drawings-together-for-printing.html
How-do-I-concurrently-adjust-the-length-and-the-angle-of-a-line-or-wall.html
How-do-I-control-the-Opening-Position-within-a-wall.html
How-do-I-copy-a-drawing-onto-a-disk-in-SoftPlan.html
How-do-I-copy-a-Material-Definition-file-from-one-system-to-another.html
How-do-I-create-a.pdf-file-from-my-SoftPlan-drawings.html
How-do-I-create-a-3.5-partition-wall-that-is-bearing.html
How-do-I-create-a-brick-ledge-in-a-slab.html
How-do-I-create-a-Concrete-Wall-with-a-brick-ledge.html
How-do-I-create-a-flat-roof.html
How-do-I-create-a-gambrel-roof.html
How-do-I-create-a-plot-file.html
How-do-I-create-a-trapezoid-window-to-follow-the-pitch-of-the-roof.html
How-do-I-create-an-exterior-concrete-landing.html
How-do-I-create-scissor-trusses.html
How-do-I-Cut-and-Paste-text-from-a-Word-document-into-SoftPlan.html
How-do-I-display-Opening-sizes.html
How-do-I-display-product-codes.html
How-do-I-draw-a-cased-opening.html
How-do-I-draw-a-countertop-over-a-dishwasher.html
How-do-I-draw-a-Foundation-Vent.html
How-do-I-draw-a-mansard-roof.html
How-do-I-draw-a-prow-roof.html
How-Do-I-Draw-a-Prow.html
How-do-I-draw-a-rectangular-transom-window-above-another-opening-without-a-gap-between-them.html
How-do-I-draw-a-reverse-gable.html
How-do-I-draw-a-thicker-line.html
How-do-I-draw-a-wall-of-half-block-or-half-concrete-and-half-frame.html
How-do-I-draw-a-wall-on-an-angle.html
How-do-I-draw-an-arched-opening-in-a-wall.html
How-do-I-draw-an-item-such-as-a-symbol-on-an-angle.html
How-do-I-draw-caissons-beneath-the-basement-walls.html
How-do-I-draw-the-joist-so-that-they-follow-my-bay-window.html
How-do-I-draw-the-vent-in-a-gable-end.html
How-do-I-draw-two-separate-windows-stacked-one-above-the-other-with-a-gap-between-them.html
How-do-I-e-mail-a-drawing-to-a-client-if-he-does-not-have-SoftPlan.html
How-do-I-enlarge-a-print-of-a-drawing.html
How-Do-I-Enlarge-Softplan-to-Fill-the-Entire-Screen.html
How-do-I-ensure-that-a-line-is-starting-at-the-endpoint-of-an-existing-line.html
How-do-I-ensure-that-my-opening-is-6-from-the-wall-corner.html
How-do-I-ensure-that-my-symbols-and-cabinets-are-always-drawn-in-the-correct-orientation.html
How-do-I-enter-in-a-custom-scale-size-for-printing-such-as.html
How-do-I-erase-just-one-cabinet-When-I-attempt-to-erase-one.html
How-do-I-export-a-Material-Report-into-Microsoft-Excel.html
How-do-I-fill-a-circle-solid.html
How-Do-I-Free-My-Cursor-From-Being-Locked-Into-Horizontal-and-Vertical-Movement.html
How-do-I-generate-a-Bird's-Eye-drawing.html
How-do-I-generate-a-report-so-as-to-have-my-lumber-list-out-to-2-foot-increments.html
How-do-I-generate-a-side-elevation-from-the-inside-of-a-“U'-shaped-house.html
How-do-I-generate-a-Stick-Frame-3D-image-of-my-building.html
How-do-I-get-extensions-to-pull-from-the-outside-of-a-stud.html
How-do-I-get-notes-to-display-in-other-modes-instead-of-just-Drawing-mode.html
How-do-I-get-one-panel-of-a-double-door-fixed.html
How-do-I-get-the-blue-backgrounds-of-the-3D-trees-in-my-rendering-to-match-my-sky-background.html
How-do-I-have-dimensions-round-up-to-1-8-accuracy.html
How-Do-I-Import-a-Portable-Document-Format-File.html
How Do I Import an AutoCAD® Dwg File Into SoftPlan?
Import_AutoCAD.html
How-do-I-include-light-sources-when-creating-new-Electrical-Symbols.html
How-do-I-insert-a-logo-into-SoftPlan.html
How-Do-I-Insert-a-Logo-Into-Softplan.html
How-do-I-install-DirectX-if-I-did-not-install-it-during-the-SoftPlan-installation.html
How-Do-I-Install-Review.html
How-do-I-install-the-Master-Key-Manager-software.html
How-do-I-install-the-SoftPlan-WorkStation-software.html
How-Do-I-Keep-Site-Bearings-From-Changing-When-I-Rotate-the-Site-Plan.html
How-do-I-keep-walls-from-joining-every-time-I-run-a-Cleanup.html
How-do-I-know-what-sequence-numbers-are-in-use-with-SoftList.html
How-do-I-maintain-my-color-changes.html
How-do-I-make-a-beam-maintain-the-offset-I-have-given-it.html
How-do-I-make-my-railing-spindles-run-horizontal-like-cable-instead-of-vertical.html
How-do-I-make-my-transom-display-in-the-gable-end.html
How-do-I-make-the-3D-Camera's-viewing-parameters-wider.html
How-do-I-make-the-Opening-Frame-the-full-width-of-the-wall.html
How-do-I-modify-the-default-depth-on-rafters-to-be-4-rather-than-6.html
How-do-I-modify-the-footing-sizes-on-my-walls.html
How-do-I-modify-the-saved-Detail-Symbols.html
How-do-I-move-an-Opening-Dimension.html
How-do-I-offset-the-garage-slab-separately-from-the-basement-slab.html
How-do-I-place-a-gable-end-window.html
How-do-I-place-a-transom-over-a-door.html
How-do-I-place-Crown-Molding-on-my-cabinets.html
How-do-I-place-the-Horizon-where-I-want-it.html
How-do-I-plot-one-drawing-at-1-8-=-1'-0-and-another-at-1-4-=-1'-0-on-the-same-sheet.html
How-do-I-position-my-light-source's-placement.html
How-do-I-print-half-tones-(shades).html
How-do-I-print-my-Cross-Section-to-an-actual-scale.html
How-do-I-print-my-fonts-as-solid-fill-rather-than-hollow.html
How-do-I-print-out-at-a-1-=10'-scale.html
How-do-I-print-out-paint-patterns-using-different-colors-for-different-patterns.html
How-do-I-print-with-a-border-in-SoftPlan-Lite.html
How-do-I-pull-a-drawing-out-of-the-Recovery-file.html
How-do-I-pull-an-extension-90-degrees-to-screen-from-a-corner-that-is-45-degrees-to-screen.html
How-do-I-pull-dimensions-from-the-corner-of-the-building-outline-to-the-property-when-they-are-not-parallel.html
How-do-I-pull-extensions-from-a-wall-to-show-the-length-of-each-panelized-section.html
How-do-I-remove-the-shading-from-cabinets.html
How-Do-I-Replace-the-Softplan-Logo-On-the-System-Drawing-Borders-with-My-Own.html
How-do-I-select-a-dimension-number-to-move-to-another-place-on-the-dimension-string.html
How-do-I-send-a-file-through-e-mail.html
How-do-I-set-up-dimension-and-extension-options-specific-to-walls.html
How-do-I-set-up-my-elevation-to-print-with-a-thicker-pen-on-certain-lines.html
How-do-I-show-a-sloped-site-in-SoftView-3D.html
How-do-I-show-exposed-rafter-tails-in-SoftView.html
How-do-I-show-reflections-on-windows.html
How-do-I-slope-the-top-of-a-wall-for-a-Vaulted-Ceiling-or-for-a-sloped-Retaining-Wall.html
How-do-I-specify-a-pen-for-Symbols.html
How-Do-I-Stop-the-Area-From-Moving-Where-I-Placed-it.html
How-do-I-stop-the-walls-from-protruding-through-the-roof.html
How-do-I-transfer-my-System-information-from-Version-11-12-to-Version-13.html
How-do-I-turn-off-Opening-Dimensions.html
How-do-I-turn-off-Opening-sizes.html
How-do-I-turn-off-the-logo-on-my-SoftList-material-report.html
How-do-I-uninstall-SoftPlan.html
How-do-I-update-my-old-Version-to-my-new-upgrade.html
How-do-I-use-the-texture-assignments-from-this-image-on-another-3D.html
How-do-the-Automatic-Updates-work.html
How-do-you-assign-nosing-to-a-stair.html
How-do-you-move-infomation-from-old-versions-into-SoftPlan-2012.html
How-is-a-garage-door-cutout-handled-in-the-foundation-plan.html
How-Many-Users-Does-SoftPlan-Have.html
How-Often-Do-Updates-Come-Out.html
How-should-I-import-drawing-files-from-previous-versions-of-SoftPlan.html
How-to-assemble-a-Multi-Drawing-Includes-Partial-Drawing-and-Scaling-Part-2-of-2.html
How-to-assemble-a-Multi-Drawing-Includes-System-Drawings-and-Border-Title-Block-Part-1-of-2.html
How-to-change-the-direction-of-joist-on-a-drawing-that-have-been-added-using-either-Ring-+-Plate-+-Subfloor-+-Joist.html
How-to-dimension-to-the-center-of-a-Post.html
How-to-display-my-walls-in-a-Solid-format-for-presentation-work.html
How-to-Erase-Reference-Points.html
How-to-generate-a-Wall-Panel-Diagram.html
How-to-generate-such-landscape-items-as-grass.html
How-to-get-a-cut-out-for-Garage-doors-in-the-Foundation.html
How-to-move-my-dimension-number-off-the-dimension-line.html
How-to-unbind-cabinets.html
How-would-I-create-a-sign-that-will-display-in-a-3D-view-of-my-building.html
I-am-attempting-to-customize-my-toolbar-and-can't-replace-or-remove-some-icons-What-should-I-do.html
I-am-creating-a-duplex-and-would-like-to-just-have-a-mirrored-copy-of-a-plan-already-drawn.-How-do-I-do-this.html
I-am-getting-the-following-error-when-I-start-SoftPlan-Error-711-The-system-clock-on-your-computer-has-been-incorrectly-modified.-To-correct-this.html
I-am-missing-my-SoftPlan-fonts.-How-can-I-get-them-installed.html
I-am-not-able-to-install-the-second-installation-disk.-I-get-a-message-The-3D-Symbols-and-Textures-DVD-was-not-found-at-the-specified-location.-P.html
I-am-trying-to-draw-a-dimension-to-a-symbol.html
I-am-unable-to-position-my-border-after-using-Multi-Drawing-to-import.-How-do-I-do-this.html
I-Am-Unable-to-Remove-a-Complete-Deck-From-the-Plan-It-Appears-to-Be-in-Pieces-Why-is-This.html
I-am-using-SoftPlan-Lite-how-do-I-create-a-stacked-opening.html
I-can't-see-any-volutes-on-my-Stairs.html
I-can't-see-my-site-property-in-3D.html
I-can't-see-my-stairs-in-elevation.html
I-can't-seem-to-locate-my-saved-Material-List-Reports-or-3D-image-files.-Why.html
I-can't-use-my-mouse-to-scroll-through-popup-menus.html
I-copied-my-SoftPlan-12-Projects-over-to-SoftPlan13.-When-I-build-a-3-Dimension-the-textures-are-now-missing.html
I-copied-SoftPlan-from-one-system-to-another.html
I-created-my-own-electrical-switch,-but-now-I-cannot-seem-to-pull-an-arc-from-it.html
I-Do-Not-Have-a-Plotter-or-Large-Printer-How-Do-I-Output-My-Drawings.html
I-get-messages-that-appear-when-I-start-SoftPlan-that.html
I-had-symbols-on-my-drawing-and-now-when-I-open-the-drawing.html
I-have-3-different-walls-meeting-at-a-T-intersection.-How-can-I-get-them-to-join-properly.html
I-have-a-parallel-port-key-for-SoftPlan-and-my-computer-does-not-have-a-parallel-port.-Is-there-something-that-can-be-done-to-make-this-key-work.html
I-have-accidentally-saved-my-work-in-the-Recovery-Folder.-How-can-I-move-this-to-another-Folder.html
I-have-added-a-texture-to-my-3D-rendering,-yet-it-displays-the-texture-multiple-times-rather-than-once.-For-example,-I-see-several-cabinet-doors.html
I-have-an-old-style-parallel-port-key-that-seems-to-be-required-when-old-drawings-are-opened.-Is-there-any-way-that-I-can-avoid-having-to-plug-in.html
I-have-created-a-new-sink-symbol-but-I-can-see-the-countertop-through-it-in-SoftView.-Why.html
I-have-drawn-an-arc-with-a-solid-fill-texture.html
I-have-Extracted-Framing-but-my-floor-joists-still-do-not-display.-How-do-I-view-the-joists.html
I-Have-Lost-My-Cross-Hairs-From-the-Cursor-How-Do-I-Get-These-Returned.html
I-have-lost-my-cross-hairs-from-the-cursor-How-do-I-get-these-returned.html
I-have-physically-broken-my-key-what-do-I-need-to-do.html
I-have-SoftPlan-Lite,-some-of-the-commands-in-the-menus-are-grayed-out-and-I-cannot-select-them,-why.html
I-have-the-software-installed-on-the-WorkStation.-How-do-I-register-it.html
I-have-Windows-98-and-since-updating-to-version-13.4.0-I-can-no-longer-see-notes-on-my-drawings.html
I-installed-SoftPlan-and-the-mouse-scroll-wheel-does-not-work-for-panning-and-zooming-on-the-SoftPlan-screen.html
I-installed-SoftPlan-and-updated-with-the-patches-to-the-most-recent-release-but-I-forgot-to-install-SoftTalk.-I-then-installed-SoftTalk.html
I-installed-Version-13-and-when-I-open-the-program-I-get-Error-100-The-SoftPlan-Key-Device-Driver-has-not-been-installed-on-this-system.-It-must.html
I-made-changes-to-the-floor-system-in-Floor-System-mode-and-the-elevation-offsets-of-the-walls-did-not-change.html
I-need-items-like-symbols-to-display-in-other-modes.html
I-own-SoftList,-does-my-upgrade-cost-more.html
I-reinstalled-SoftPlan-and-now-when-I-attempt-to-open-my-drawings-I-receive-the-message-This-drawing-was-created-with-a-newer-version-of-SoftPlan.html
I-reversed-my-elevation-and-lost-all-dimensions.html
I-set-the-Building-Permit-formula-to-Include-=-Yes-and-I-get-two-Building-Permits-listing.html
I-updated-to-the-current-version-and-the-watermark-is-still-dark.html
I-upgraded-to-Version-14-but-did-not-receive-a-Master-Station-program.html
I-used-File-Export-from-a-floor-plan-in-SoftPlan-and-tried-both.dwg-and.dxf-formats.-The-file-that-was-exported-did-not-maintain-3-Dimensional-in.html
I-want-to-be-able-to-print-a-list-of-the-symbols-I-have-available-in-the-program.html
If-I-make-changes-or-additions-to-a-saved-elevation-will-they-display-in-3D.html
If-my-roof-reference-circle-is-referenced-to-the-wrong-wall-can-I-move-it.html
Illustrated-&-Sketched-Mode-Draw-Menu-Item-Added-to-SoftView-Save-Elevations.html
Illustrated-and-Sketched-Mode-Added-to-SoftView.html
v14features_SoftView_illustrated.htm
I'm-running-SoftPlan-over-a-network-from-a-centralized-server.-Where-do-I-attach-the-SoftPlan-keys.html
I'm-unable-to-plot-landscape-on-an-HP-Design-Jet-200-series-plotter.html
Import-&-Export-of.3DS-and-SketchUp-Files-3D-reView.html
Import-an-AutoCAD.DWG-file-into-SoftPlan-How-to-Import-a-DWG-File-and-How-to-Quickly-Convert-that-File-to-a-SoftPlan-Drawing.html
Import-Export-of.3DS-Files-and-SketchUp-Files-Added-to-SoftView.html
In-3D-Material-what-is-the-difference-between-the-Color-and-Texture-assignments.html
In-Floor-System-mode-there-is-an-item-called-a-Ring-Joist.-What-is-a-ring-joist.html
In-Roof-Mode-my-exterior-walls-are-being-displayed.html
In-Site-Mode-I-Need-to-Measure-Angles-Relative-to-360-Degrees-Rather-Than-Quadrants-How-Do-I-Do-This.html
v14features_SoftView_incremental1.htm
v14features_SoftView_incremental.htm
Individual-Studs-Can-Be-Added.html
v14features_wall_framing_individual.htm
v14features_drawing_popup.htm
Information-Popup-Added-to-the-Right-Mouse-Button.html
v14features_wall_align.htm
v14features_dimensions_extensions_string.htm
v14features_tools_polygon.htm
Back | Print
Install-&-Update.html
SoftPlan understands that some of our users value the added convenience of specialized training. As a result, the SoftPlan Interactive Training DVDs were designed by our own technical support staff to enhance our users’ ability to realize the full potential of SoftPlan home design software. The DVDs are a comprehensive, hands on training tool that allows concepts to be readily understood through step-by-step explanations. And as an added bonus, the DVDs makes a great supplement to the Learning SoftPlan Manual and are an excellent reference tool.
Interactive-Training-DVDs.html
Interior-3d.html
Interior-Dimensions.html
v14features_opening_interior_trim.htm
Interiors Coverage Option Added to Wall Coverings The type of coverage can be specified when applying Wall Coverings in Interior mode. By editing the Wall...
v13features_interiors.htm
2012_Interiors.html
Baseboard is Correctly Positioned When the Slab is Non-Structural When Baseboard is placed along walls it will automatically locate the bottom of the wall for it’s placement. But when a...
interiors_basebd-position.htm
Interiors Additional Wall Covering Icons Added In Version 14 the additional wall covering icons added allow more and different style of wall coverings...
v14features_interiors.htm
Back | Print
Intermediate-4-Day.html
Intermediate-Level-Chapter-31-Multiple-Floor-Roof-Learn-How-to-Add-a-Two-Story-Roof.html
Intermediate-Level-Chapter-5-Kitchen-Design-Learn-How-to-Layout-a-Kitchen-Using-Symbols-and-Cabinets.html
v14features_railings_intermediate_post.htm
Intermediate-Training-Video-Sample.html
v14features_roof_two_pitches.htm
Introductory-Level-Chapter-6-Interior-Walls-Learn-How-to-Add-Interior-Walls-to-Your-Floorplan.html
v14features_shapes_solids_invert.htm
Is-it-possible-to-change-the-printable-area-that-I-see-when-I-select-the-Position-Print-Window.html
Is-it-possible-to-copy-a-window-in-plan.html
Is-it-possible-to-copy-the-Wall-Types-from-a-drawing-and-import-them-into-the-System-Options-Wall-Definition-List.html
Is-it-possible-to-directly-merge-a-drawing-into-a-multi-drawing-set.html
Is-it-possible-to-draw-insulation-in-a-general-cross-section.html
Is-it-possible-to-generate-a-splay-on-the-roof-edge.html
Is-it-possible-to-have-a-door-and-sidelights-treated-as-one-unit.html
Is-it-possible-to-have-the-shading-that-displays-on-my-roof-and-floor-systems-to-print.html
Is-it-possible-to-have-two-drawings-of-different-scales-on-the-same-sheet-in-SoftPlan-Lite.html
Is-SoftPlan-compatible-with-64-bit-systems.html
Is-there-a-difference-between-Enlarge-Dimension-Numbers-and-changing-the-size-in-Character-Setup.html
Is-there-a-Search-command-for-finding-symbols-in-the-different-libraries.html
Is-There-a-Setup-in-Softplan-to-Increase-the-Size-of-the-Icons.html
Is-there-a-way-to-add-drywall-to-a-hole-in-a-floor-system-or-ceiling-system.html
Is-there-a-way-to-automatically-have-the-program-generate-with-wider-shutters.html
Is-there-a-way-to-change-the-cursor-crosshairs-color.html
Is-there-a-way-to-control-what-is-printed-and-what-is-not.html
Is-there-a-way-to-remove-the-wall-thickness-dimension-display.html
Is-there-a-way-to-see-Crown-Mold-or-other-interior-items-drawn-on-the-exterior-of-the-drawing-when-in-an-elevation-I-was-not-prompted-with-Extrac.html
Is-there-a-way-to-specifically-locate-an-item-so-as-to-be-sure-that-another-item-is-not-selected-instead.html
Is-there-an-easy-way-to-insert-a-border.html
Is-There-an-Easy-Way-to-Insert-a-Border.html
Is-there-an-option-for-a-reflected-ceiling-plan.html
Is-there-an-option-to-change-the-Dimension-and-Opening-Dimension-text-sizes-in-SoftPlan-Lite.html
Is-there-any-difference-between-the.prn-extension-that-is-added-to-a-plot-file-and-the.plt-extension-that-earlier-versions-of-SoftPlan-used.html
Is-there-any-way-to-change-the-size-of-the-cabinet-names.html
Is-there-any-way-to-have-the-floating-toolbar-remain-open-on-screen.html
Is-There-Any-Way-to-Open-Softplan-So-That-it-is-Fully-Maximized-On-Screen-All-the-Time.html
Is-there-any-way-to-save-a-SoftPlan-drawing-in-another-format-other-than-bitmap-(.bmp).html
Is-there-anyway-to-bypass-a-wall-when-stringing-dimensions.html
Is-there-anyway-to-specifically-locate-a-post-that-is-under-a-beam-without-moving-the-beam.html
v14features_misc_cleanup.htm
v14features_floorsystem_items.htm
I've-purchased-a-new-computer.-Prior-to-installing-the-new-SoftPlan-Version.html
I've-seen-openings-in-3D-that-are-open,-how-do-I-do-that.html
v14features_wall_framing_stud_jack.htm
v14features_cabinets_join.htm
v14features_print_joist_pen.htm
Key-Driver.html
Back | Print
Keys_support_FAQ.html
Keys.html
Kitchen-Layout.html
v14features_print_remember.htm
Lathe Lathe Template Used to Create Turned Profiles to Be Placed Into the Lathe Library Use the Lathe Template to create custom shapes for the stairs Posts, Newels,...
v13features_lathe.htm
v14features_lathe.htm
v14features_layers_export.htm
v14features_layers_setup_toolbar.htm
Layers Ability to Lock Layers Feature Added A Lock selection is available on the Layer Setup dialogs. Items assigned to the Layer cannot be erased or moved....
v14features_layers.htm
2012_Features_Layers.html
Layers.html
Layers Layers Feature Added To give you more visibility control, you can use Layers. Layers can be used to group a series of items that you want to associate...
v13features_layers.htm
v14features_layers_type_erase.htm
Laying-Out-a-Floor-Plan.html
Libraries-How-to-Sort.html
v14features_SoftView_lighting_mode.htm
v14features_SoftView_layers_saved.htm
v14features_cross_section_layers.htm
Lines-in-Elevation-Are-on-a-Different-Layer-Than-Lines-in-Section-on-a-Saved-Cross-Section.html
v14features_stairs_link_floors.htm
Links.html
v14features_SoftList_materials.htm
Live-Demo.html
SoftPlan live online training classes that you may attend from the convenience of your own office/home on your computer. The online class will be conducted using SoftPlan 2012. Choose to attend either the two day class that meets for half days or the four day class which is divided into 90 minute sessions each day. These content-rich webinars provide loads of insightful tips and valuable information. The online classes are taught by our very own technical support and training staff. From your computer you will be able to see the instructor’s screen and hear them speak, as if they were right there with you in your office! Each class includes a question and answer period at the end of each day.
Live-Online-Training.html
v14features_electrical_locate.htm
v14features_beams_log_profile.htm
Log-Walls.html
v14features_SoftList_lumber.htm
Back | Print
Lumber-Yard.html
SoftPlan home design software manufacturer catalog
Manufacturer-Content.html
Many-People-Tell-Me-They-Use-Autocad-to-do-their-drawings-and-that's-what-I-should-buy.-What-makes-SoftPlan-a-better-choice.html
v14features_reView_arrow.htm
Download Master Key Manager for SoftPlan Network Installation
Master-Key-Manager.html
v14features_stairs_material_types.htm
Message-reads-not-enough-memory-when-plotting-a-multi-drawing.html
2012_Miscellaneous.html
Miscellaneous Elapsed Time Command Added Track the time spent on a particular drawing using Elapsed Time. It will tell you information such as the time and...
v13features_misc.htm
Mirror Command Added SoftPlan Version 12 has streamlined the ability to make reverse copies of objects into one simple command called Mirror. Simply use this command to select the objects which are...
misc_mirror.htm
Miscellaneous Add Product Code Added to the List of Password Protected Configuration Settings Glulam...
v14features_misc.htm
Modes Custom Modes Added Version 13 has expanded the available modes to include 5 Custom modes. This allows creating additional plans with more customized...
v13features_modes.htm
Modes SoftList Mode Added SoftList Mode is used to estimate quantities for both SoftPlan and non-SoftPlan (imported .PDF or .DWG files). ...
v14features_modes.htm
2012_Modes.html
2012_Move.html
Move Align to Edge Command Added The Align to Edge can be used in a situation where one object on a plan needs to align its edge to the edge of...
v13features_move.htm
Move Align to Edge Can Access Walls on an Overlayed Drawing The Align to Edge can be used in a situation where one object on a plan needs to align its...
v14features_move.htm
v14features_decks_move_wall.htm
Movie-SoftTalk.html
2012_Multi-Drawing.html
v14features_notes_multi.htm
v14features_ceiling_multiple.htm
Multiple-Floor-Roof.html
v14features_SoftList_delete_multiple.htm
v14features_layers_multiple.htm
My-@date-and-@time-features-are-not-working-How-do-I-correct-this.html
My-brick-wall-is-stopping-short-of-the-siding-wall-how-do-I-reverse-it.html
My-custom-defined-wall-is-not-showing-in-the-Drawing-Wall-list.-How-do-I-correct-this.html
My-D-size-border-does-not-fit-inside-the-Print-Scaling-Window.html
My-DXF-DWG-of-a-site-plan-is-not-at-1-1.-How-do-I-get-it-at-1-1.html
My-generated-elevation-is-not-displaying-any-openings-How-do-I-correct-this.html
My-printer-can-print-on-11-x17-paperSoftPlan.html
My-SoftPlan-Version-12-or-earlier-will-not-print.html
My-Toolbar-Icons-Disappear-Off-the-Right-Edge-of-the-Screen-How-is-This-Corrected.html
My-walls-are-not-forming-a-proper-corner.-One-wall-continues-to-overlap-the-other-How-do-I-correct-this.html
My-walls-are-protruding-through-my-roof.-How-do-I-correct-this.html
My-walls-are-protruding-through-the-roof-since-I-changed-the-wall-heights.-How-do-I-correct-this.html
v14features_cabinets_name_override.htm
v14features_electrical_new_lights.htm
v14features_electrical_lights.htm
SoftPlan Pricing
SoftPlan-New-Product-Pricing.html
New-Southern-Home-Mode-Animation.html
v14features_walls_texture_block.htm
Newsletters.html
Easier to Change the Size of a Note with Review Notes Version 12 has made it Easier to change the size of a note with review notes. 1. Add a note to a drawing, if it is a Speed Note, you will need to...
notes_size.htm
Notes Auto Label Wall Only Displays Significant Digits of the Height Extra zero have been removed from wall heights so that only significant digits are displayed in...
v14features_notes.htm
Back | Print
Notes_support_FAQ.html
2012_Notes.html
Notes Auto Label Command Added The Auto Label command for Notes can be used to select an object on the plan and automatically display specific data for that object...
v13features_notes.htm
Notes-and-dimensions-are-printing-out-too-small-at-the-scale-I-want-to-use.html
v14features_building_options_250.htm
v14features_stairs_number_stringer.htm
v14features_opening_number_grille.htm
v14features_SoftList_ODBC.htm
v14features_interiors_offset.htm
On-a-Generated-Material-Report-some-entries-are-being-cut-off-during-the-print.html
On-close-zooms-why-is-my-mouse-so-jumpy.html
On-plumbing-symbols-how-to-I-indicate-the-drain-locations-so-that-I-can-see-them-in-Floor-System-mode.html
On-what-floor-plan-should-I-put-my-floor-systems.html
On-Windows-XP,-why-are-1-8-increment-fractions-not-displaying-or-printing.html
With SoftPlan's One-on-One Online Instruction, enjoy eight hours of personal instruction sessions that may be spread out over the course of a year on the topics of your choosing. You’ll be able to have your very own private SoftPlan instructor for online sessions to help you get the most out of your SoftPlan home design software.
These instructors are experts in SoftPlan and they will teach you anything you would like to learn in the program.The online sessions are powered by the technology of GoToMeeting®. With a high-speed internet connection, you will be able to connect directly to your instructor’s computer screen where the two of you will work together on the chosen subject. The instructor will also be able to work on your screen. Prior to the session, a training representative will coordinate with you to schedule a training time and select a curriculum.
One-on-One-Online-Instruction.html
One-on-One-Training-Video-Sample.html
v14features_openings_SoftList.htm
v14features_type_erase_present.htm
v14features_openings_top.htm
v14features_opening_ID.htm
v14features_opening_offset.htm
v14features_opening_jamb_size.htm
v14features_opening_elevation.htm
v14features_opening_trim_inset.htm
Quoins and Corner Boards Will Display in Plan View SoftPlan Version 12 has expanded the option of display Quoins & Corner Boards in plan to also include any exterior trim and/or keystone which...
opening_quoins.htm
2012_Features_Openings.html
Back | Print
Openings.html
Openings 36” Wide Interior Doors Added to Library SoftPlan has provided more sizes of standard Interior doors which include the 36” wide. ...
v13features_openings.htm
Openings Arch Chamfered Maintains the Size of the Chamfer As the Width of the Arch Is Changed Baseboard...
v14features_openings.htm
v14features_visible_items_opening.htm
Openings-How-to-Draw-and-Customize-Openings.html
Orbit-Mode-Added-to-SoftView.html
SoftPlan Online Order Sheet.
Order.html
orderonline_cart_new.html
Our-Company-Has-Moved-How-Do-I-Update-the-Address.html
Our company needs more than one copy of SoftPlan. Is there a discount on additional seats?
Our-Company-Needs-More-Than-One-Copy-of-SoftPlan-Is-There-a-Discount-On-Additional-Seats.html
v14features_symbols_outdoor.htm
v14features_cabinets_corner.htm
v14features_print_overlay.htm
Overview-of-Some-of-the-Major-New-Features.html
Paint Arc Cords Do Not Act as a Paint Boundary Line Styles Maintained When Pattern Is Defined Paint and Shade Break Lines Use the Shape Auto...
v14features_paint.htm
2012_Paint.html
Paint Default Pen Selection Added to Edit Dialog The Paint Edit dialog now gives the option of using the default pen for Paint or enabling the option to choose a...
v13features_paint.htm
Earth Pattern and Wood Grain Pattern Added SoftPlan’s Paint pattern libraries have been expanded to include both an earth and a wood grain pattern. Click below to view an example of these patterns....
paint_patternsadded.htm
Paint-disappears-from-the-screen-when-I-perform-a-Cleanup-or-Print.html
v14features_paint_visible_paint.htm
Partial-Option.html
v14features_print_partial.htm
Partial-Option-Added-to-the-Multi-Drawing-Paste-from-Windows-Clipboard.html
Patches.html
v14features_SoftList_path.htm
Pen Assignment Print Pen Override Added to the Edit Symbol and the Electrical Symbol Dialog With the Print Pen override that has been added to the Edit Symbol and...
v14features_pen_assignment.htm
v13features_pen_assignment.htm
Site Lines Added to Pen Assignment oftPlan Version 12 has added the ability to now configure the print pen settings for your Site Lines. This feature was previously unavailable in earlier versions of...
snap_perpendicular.htm
v14features_posts_pen.htm
v14features_room_pen.htm
v14features_print_rod.htm
Placing-Appliances-&-Plumbing.html
v14features_railings_plan_position.htm
v14features_roof_different_heights.htm
v14features_site_polytab.htm
Pad Inset No Longer Affects the Offset of a Post SoftPlan Version 12 has changed the way a Post’s Pad (footing) will inset into a Post. A Pad Inset is used to push the footing into the post, rather...
post_padinset.htm
Posts Adjust Height to Fit to Beam Option Added Within the Post Edit dialog is the option ‘Adjust height to fit to beam.’ When selected, the program will...
v13features_posts.htm
Posts 20 High Quality Columns Added to Library SoftPlan now has 20 new columns in its library of predefined posts. ...
v14features_posts.htm
2012_Posts.html
Back | Print
Posts-&-Beams.html
Posts-&-Beams-2012.html
v14features_railings_spindle.htm
v14features_SoftView_export_POV.htm
v14features_openings_prarie.htm
v14features_posts_pressure.htm
Previous-Version-Upgrades.html
SoftPlan product pricing
Pricing.html
Print @Print Commands Added for Project Information Entered Under File-Project Information @Scale Print Command...
v14features_print.htm
The Print Dialogue Remembers the Last Printer Used SoftPlan Version 12 will recall the last printer used by SoftPlan, not necessarily the default printer as previous version did. This should speed up...
print_recall.htm
2012_Print.html
Print Area @area Print Variable Added By simply adding a SoftPlan Information Stamp as a Note to the drawing, the corresponding area from Area mode can be...
v13features_print.htm
Print-incudes-Title-Blocks-and-Multi-Drawings.html
v14features_notes_print_pen.htm
v14features_notes_regenerate.htm
v14features_layers_print_pen.htm
v14features_SoftList_print_range.htm
Printed-lines-are-coming-out-faint-and-the-text-looks-as-if-it-is-made-up-of-dots.html
Printed-Lines-are-not-the-proper-thickness-or-color.html
Back | Print
Printing.html
Privacy.html
v14features_modes_preview.htm
Profiles-Added-to-Beams-and-Walls.html
v14features_shapes_solids_frustum.htm
Back | Print
Quick-Start-2-Day.html
Back | Print
Quick-Start-4-Day.html
Railings Horizontal Spindle Option Added Version 13 now has the ability to change the orientation of railing spindles to horizontal. This is useful where the...
v13features_railings.htm
Turned Spindles Added Another option for spindle styles has been added to Version 12. The turned spindle style can be found under the Railing Options. Although the plan view of the railing drawn that...
Railings_turndedspindles.htm
Railings Deflection Option Added Intermediate Post Option Has Been Added ...
v14features_railings.htm
2012_Railings.html
v14features_railings_handrail.htm
v14features_rake_bottom.htm
v14features_SoftView_relief_depth.htm
Back | Print
Remodeler.html
Back | Print
Remodeler-Wall-List.html
v14features_opening_renumber.htm
Repeat-Edit.html
v14features_cabinets_topheight.htm
v14features_SoftList_columns.htm
Request_One_on_One_Training.html
REScheck.html
REScheck-Energy-Compliance.html
v14features_site_reverse.htm
2012_features_reView.html
Back | Print
Review.html
v14features_reView_3D.htm
v14features_notes_resizable.htm
SoftPlaln reView Frequently Asked Questions Is there a charge for SoftPlan reView? Will I be able to import my customer’s comments and markups back into my SoftPlan drawing? Will...
reView_FAQ.htm
v14features_roof_ridge_extension.htm
v14features_roof_ridge_cap.htm
v14features_system_options_rod_shelf.htm
v14features_drawing_rodshelf.htm
v14features_drawing_multiple_shelves.htm
Back | Print
Roof.html
2012_features_Roof.html
Roof Add Cricket Command Added Automatically add a cricket anywhere along a higher wall edge on a roof with this new command. A cricket is a built-up roof required between a wall...
v13features_roof.htm
Roof Add Shed Roof Command Added Watch Movie Adjust a Roof Reference Point onto a Curved Wall and the Roof Edge Becomes Curved Apply Gable...
v14features_roof.htm
Adding of Gable Ends on Multiple Floor Roof Improved Improvements have been made with regard to the way that Gable ends on a roof are recognized and extracted in a Multiple Floor roof situation. When...
roof_multfloor.htm
v14features_type_erase_roof.htm
Roof-Design.html
Roof-Design-How-to-Assemble-a-Complex-Roof-that-Spans-Multiple-Floors.html
Back | Print
Roof-Fly-Around.html
Roof Framing Dimensions and Extensions Can Be Added and Edited in Roof Mode Attic Truss Type Added Attic Truss has...
v14features_roof_framing.htm
Roof Framing Dimensions and Extensions Can Be Added and Edited in Roof Mode Dimensions and Extensions can be added and edited in Roof mode making it easy to modify aspects...
v13features_roof_framing.htm
2012_Roof-Framing.html
Roof-Framing_V14.html
v14features_roof_framing_ends.htm
Back | Print
Roof-Movie.html
Roof-Profile.html
Back | Print
Roof-Profile.html
Roof-Training-Sample,-Chapter-15-Multiple-Floor-Roof.html
Roof-Trusses.html
v14features_roof_type_option.htm
Back | Print
Roofs_support_FAQ.html
Roofs.html
2012_Room.html
Room Butler Pantry, Storage Room, Screened Porch, Deck Room, Game Room, Patio, Mud Room, and Hearth Room Added ...
v14features_room.htm
Room-Design-Size.html
v14features_room_design_size.htm
Room-Finish-Schedule.html
v14features_misc_roomschedule.htm
v14features_room_finish_schedule.htm
v14features_room_names.htm
Rooms.html
Rooms-2012-Demo.html
v14features_roof_edit_saddle.htm
Samples.html
v14features_SoftView_save_elevations.htm
Saving-Elevations.html
Saving-Sections.html
SoftPlan Training Schedule
Schedule.html
v14features_openings_screen.htm
v14features_wall_multiple_select.htm
v14features_layers_select.htm
v14features_copy_move.htm
Selection-Sets.html
v14features_drawing_selection_set.htm
v14features_edit_step_wall.htm
v14features_opening_interior_separate.htm
Set-Distance-Between.html
Set-Layer.html
Adjustment of Box Shapes SoftPlan Version 12 has modified the Adjustment of Box Shapes. When such a shape is adjusted, the sides perpendicular to the edge being adjusted will display as the box...
shape_adjustbox.htm
Back | Print
Shapes.html
Shapes & Solids Invert Option Added to Solids Pyramidal Frustum Added ...
v14features_shapes_solids.htm
Shapes & Solids Ellipse Can Be Block Cut Block cut is now possible on the Ellipse shape in order to create more custom shapes. ...
v13features_shapes_solids.htm
2012_Shapes-&-Solids.html
Shopping-Cart-New-Educational-2012.html.html
v14features_area_shaded.htm
v14features_floorsystems_shade.htm
v14features_visible_items_shaded.htm
Back | Print Back | Print
Since-installing-the-Windows-Security-update-KB890859.html
Since-installing-the-Windows-Security-update-KB891711.html
Since-using-Fit-to-Roof-on-my-main-floor.html
Site Convert Shape to Site Line Command Added The ‘Convert Shape to Site Line’ command can easily convert shape lines to Site lines for use in Site mode. This new...
v13features_site.htm
Back | Print Deck Videos [SUBPAGE_BULLET_LINKS] Back | Print
Site.html
Site Generated Grade Lines Automatically Display a Shot Point at Each End Indicating Height Grade Lines can have the elevation changed via the edit dialog. ...
v14features_site.htm
Ability to Edit a Post in Site Mode You can now edit a Post in Site mode in Version 12. Previous versions of SoftPlan required you to use the Locatable Items feature before you could edit the post....
site_editpost.htm
2012_Features_Site.html
Site-How-to-create-a-topographical-site.-Part-1-of-2.html
Site-How-to-create-a-topographical-site.-Part-2-of-2.html
sitemap-page-order.html
Back | Print
Site-Plan_support_FAQ.html
Site-Plans.html
Back | Print
Site-Topography-Part-1.html
v14features_site_align_width.htm
v14features_SoftView_sketched.htm
Sketching-Openings.html
Sketching-the-Layout.html
Corner of Opening Frames Locatable by Snap SoftPlan Version 12 has added opening frame corners to the list of locatable snap points. You can now snap the cursor to any corner of an opening frame to...
snap_openingframe.htm
Snap Center of a Curved (Radius) Wall Is a Snap Point The Cursor Snap command is now able to locate the Center radius point of a curved wall. ...
v13features_snap.htm
v14features_snap.htm
v14features_SoftView_snap.htm
Back | Print
Softlist_support_FAQ.html
Softlist.html
Group Roof, Component Roof Plane, "Pitch" Variable Added Version 12 has added new variables to the Roof Group under the Component: Roof Plane. The variables; roof_pitch_a and roof_pitch_b can be used...
softlist_grouproof-pitch.htm
SoftList Add Banner Command Added SoftList now allows a logo to be added to the printed report. Add Companion Material...
v14features_SoftList.htm
Residential Design Software for Professionals
Designing with SoftPlan offers practical tools that are simple to learn and easy to use.
With more than two decades of development. SoftPlan offers a unique and industry leading solution for residential and light commercial design. Maximum automation combines with a short learning curve to create unlimited design possibilities. SoftPlan allows you to build a model of your project before you build it on the site, and your "virtual model" provides complete construction documents, 3D renderings, and accurate material list, and cost estimate reports.
The most advanced residential design software and the only one with free technical support and no annual user fees.
Working Drawings 3D Renderings Material Lists
SoftPlan Version 14 is a huge hit … SoftPlan gives me control of the 3D model which is something not easily done in AutoCAD®. SoftPlan Version 14 is very content rich, in fact the best I have seen from any program.
2012_Features_SoftList.html
SoftList Click here for Version 13 SoftList Variable Changes SoftList Locations A different location for the SoftList folder can be selected in...
v13features_SoftList.htm
SoftList-Chapter-22-Baseboard-Learn-How-to-Change-the-Default-Formulas-to-List-Using-16'-Pieces.html
Softlist-Materials-Report.html
SoftList-Materials-Will-Export-to-QuickBooks-SoftList-Will-Communicate-with-Any-ODBC-(Open-Database-Connectivity)-Estimating-an-Imported-CAD-or.html
v14features_modes_SoftList.htm
SoftList-Products-Page.html
SoftList-Training-Video-Sample.html
Back | Print
Softlist_Online_Training.html
SoftList_Version_11_Features.html
Download the latest versions of SoftPlan home design software.
SoftPlan-2012-patches.html
SoftPlan-2012.html
SoftPlan 2012 Frequently Asked Questions
SoftPlan-2012-FAQs.html
SoftPlan-2012-Features.html
SoftPlan-Corporate-Pricing.html
SoftPlan-Drawing-Basics.html
SoftPlan is pleased to offer an Educational package that is intended to be simple to use for instructional purposes while being cost effective. Teachers are amazed at how easy SoftPlan is to implement in the classroom as the program enables them to focus their time on building design concepts rather than navigating complicated software.
SoftPlan-EDU.html
"The real excitement begins with its detailed modeling capabilities that allows students to seamlessly move from two dimensional drawings to 3D exterior and interior rendered models."...
lpsoftplanedu_reviews.htm
As part of our continued commitment to education, SoftPlan has developed a secondary level curriculum for architectural drafting. This resource is FREE to all...
lpsoftplanedu_curriculum.htm
Dysart USD Signature Architecture Program Located in El Mirage, AZ, Dysart USD Signature Architecture Program prepares its students for a career in...
educational_users.htm
A partial list of schools that use SoftPlan home design software.
SoftPlan-Educational-Users.html
SoftPlan-Gallery.html
Home design software for building professionals. Quickly and easily create the "BIM model", complete construction documents, 3D renderings, accurate material lists, and cost estimate reports.
index.html
Softplan-is-Not-Retaining-the-Function-I-Select.html
SoftPlan Lite Home Design Software for the less demanding user.
SoftPlan-Lite.html
Introducing SoftPlan Network.
Reduce Costs
SoftPlan Network is a cost effective way to run SoftPlan on multiple computers in the office. It helps to eliminate the headaches of keeping track of your SoftPlan licenses, giving you less to worry about when it comes time to upgrade. If you decide to upgrade SoftPlan Network, you’ll be blown away by the savings. There’s no need to upgrade several keys, simply upgrade SoftPlan Network for a fraction of the price.
Secure Your Investment
Make sure that lost or stolen licenses are a thing of the past. SoftPlan Network gives you greater control over your investment by ensuring that the program stays at the office.
Achieve Better, More Accurate Drawings
Use SoftPlan Network to encourage your staff to implement a more unified drawing standard. Your team will achieve more consistent drawings and a better, more accurate materials list by ensuring that everyone is on the same page in terms of building materials, symbol libraries and more.
Call a SoftPlan sales representative to find out how SoftPlan Network can reduce costs in your office.
SoftPlan-Network.html
SoftPlan-News-January-2012.html
SoftPlan-News-June-2011.html
SoftPlan-News-November-2011.html
SoftPlan-Quick-Tour.html
SoftPlan-REScheck-Integration-Part-1.html
SoftPlan-REScheck-Integration-Part-2.html
SoftPlan-REScheck-Integration-Part-A.html
SoftPlan-REScheck-Integration-Part-B.html
SoftPlan reView 3D Review Added SoftPlan reView 3D allows SoftPlan reView users to send the 3D SoftView model to clients for viewing. The free reView client...
v14features_reView.htm
SoftPlan reView reView Mode Added reView mode has been added to store the reView items such as markups and redline information, service symbols, and punchlist items...
v13features_reView.htm
SoftPlan-reView.html
SoftPlan User Links
SoftPlan-User-Links.html
SoftPlan Home Design Software How to Videos
SoftPlan-Video-Library.html
SoftPlan was developed specifically to automate home design projects, SoftPlan home design software allows you to build a model of your project on your computer before you build it on the lot. SoftPlan’s “virtual model” or "BIM" model design gives you complete working drawings and realistic 3D renderings
SoftPlan_Product_Information.html
SoftPlan_Version_11_Features.html
SoftTalk.html
SoftTalk_landing_page.html
2012_SoftView.html
SoftView Always Face Camera Option Added to Symbols With Always Face Camera turned on, the Symbol will always be at 90 degrees (perpendicular) to the camera. Therefore the...
v13features_SoftView.htm
SoftView .3DS File & SketchUp® Files Import/Export Added to SoftView The new Symbol Wizard command allows 3D symbols to be imported directly from SketchUp®. 3DS...
v14features_SoftView.htm
Build Menu Automatically Opens When the Assemble Floors Dialog is Closed Version 12 has added a feature to speed up the process of generating in SoftView. When the Assemble Floors is selected and the...
softview_buildmenu.htm
SoftView-Chapter-9-Material-Assignments-Learn-About-Assigning-Textures.html
v14features_electrical_SoftView.htm
SoftView-Draw-Opening-Command.html
SoftView-How-to-Brighten-Up-an-Interior-3D-Model.html
SoftView_Version_11_Features.html
v14features_paint_solid.htm
Some-Home-Design-Software-Targeted-at-Consumers-Say-They-Include-Materials-Lists-What-Makes-SoftList-Different.html
Some-of-my-doors-appear-with-different-IDs-even-though-I-do-not-have-Unique-door-IDs-on.-Why.html
v14features_ceiling_stair.htm
2012_Feature_Stairs.html
Back | Print
Stairs.html
Flared Stairs Added SoftPlan Version 12 has added the ability to now draw a set of Flared Stairs. In previous versions this was not available. There are two methods, which can be used within in the...
Stairs_flared.htm
Stairs Default Nosing Depth Option Added to the Stair Options You can assign a default nosing depth in the Stair Options. This will apply to sketched stairs. ...
v13features_stairs.htm
Stairs Automatic Labeling Added to Stairs When you edit a stair the following automatic labeling functions are now available; Add Direction Arrow, Add Riser Count,...
v14features_stairs.htm
Stairs-2012-Demo.html
Back | Print
Standard-Wall-List.html
v14features_beams_steel.htm
Stellar-Golf-House-Animation.html
v14features_walls_step.htm
Step-Wall-Command-Added-to-Edit.html
Stick-Framing.html
v14features_symbols_stool.htm
v14features_wall_strapping.htm
v14features_stairs_stringer.htm
v14features_stairs_recessed_stringer.htm
v14features_wall_stuccoB.htm
v14features_wall_framing_stud_space.htm
v14features_wall_framing_thick.htm
v14features_wall_stud_drywall.htm
SoftPlan studio - 3D design software for consumers
v14features_wall_framing_stud_modify.htm
Suggestions.html
Suggestions-Sent.html
v14features_elevation_sun_studies.htm
Sun-Study-Elevation.html
Support.html
SoftPlan Home Design Software frequently asked questions search page
Support-FAQs.html
v14features_electrical_switch.htm
v14features_electrical_outlet.htm
2012_Symbol-Libraries.html
2012_Symbol-Manufacturer's-Libraries.html
v14features_symbols_wizard.htm
Symbols Always Face North Option Added to Symbol Definitions The Always Face North Selection has been added to the Symbol Definitions. This feature is used to...
v14features_symbols.htm
Symbols.html
Back | Print
Symbols_support_FAQ.html
Duplicate Does Not Change the Angle of a Symbol Version 12 has changed the Duplicate function so that it does not change the angle of a Symbol. Previous versions of SoftPlan would change the angle of...
symbol_duplicate.htm
Symbols 3D Symbol Preview Is Textured Rather Than Wire Frame The 3D Symbol preview now shows the assigned textures rather than a wire frame model. This gives a...
v13features_symbols.htm
2012_Features_Symbols.html
v14features_symbols_corner_snap.htm
2012_System-Options.html
System Options Archive Backups and Restores the Softview.cfg File Containing the Default SoftView Settings Option Added to Draw...
v14features_system_options.htm
System Options Archive Allows for Backup and Restore to Folders Other Than the Root of the Selected Drive Archive now allows the ability to select a folder to...
v13features_system_options.htm
v14features_layers_table.htm
v14features_building_options_tables.htm
Takeoff-Highlight-Tool.html
v14features_SoftList_takeoff.htm
v14features_opening_tall_library.htm
v14features_wall_tar.htm
Back | Print
Tech-Support.html
Technical-Support-Bulletin.html
v14features_SoftView_texture_size.htm
The.dxf.dwg-file-that-I-imported-is-just-lines-and-notes.-How-do-I-work-with-it-in-SoftPlan.html
The-DXF-DWG-that-I-imported-is-at-the-wrong-scale.-How-do-I-correct-this.html
The-Extend-Command-Isn't-Working-the-Same-Way-it-Did-in-Earlier-Versions.html
The-Fillet-Command-Isn't-Working-the-Same-Way-it-Did-in-Previous-Versions.html
The-Item-I-Select-to-Move-Displays-As-a-Box-Only-Is-This-Correct.html
v14features_print_5_scale.htm
The-lines-on-my-image-are-too-thick-can-they-be-made-thinner.html
The-Opening-Headers-appear-on-the-Walls-displayed-in-the-Background.html
The-regenerate-box-was-checked-on-the-roof.html
The-Review-File-Seems-Large-and-Slow-to-Email,-What-Can-Be-Done-to-Make-the-File-Smaller.html
The-ridge-of-my-roof-is-not-displaying-in-the-proper-location.-How-do-I-correct-this.html
There-Are-Several-Home-Design-Programs-What's-the-Difference.html
There-is-a-gray-line-running-through-my-drawing.-What-is-it-and-how-do-I-remove-it.html
Fillet Improved SoftPlan Version 12 has modified the ability to Fillet objects. In previous versions of Softplan the lines remaining after a Fillet was performed were not necessarily dictated by...
Tools_filletimprove.htm
Tools Adjust Wall Material Command Added Difference Command Added The Difference command is...
v14features_tools.htm
Tools Convert Shape to Site Line Added The ‘Convert Shape to Site Line’ command can easily convert simple lines to Site lines for use in Site mode. This new tool is...
v13features_tools.htm
2012_Tools.html
Trade Shows where SoftPlan home design software will be on display.
Trade-Shows.html
SoftPlan Home Design Software is the leading residential CAD software package for thousands of professional builders, remodelers, designers, and architects. While SoftPlan is the easiest, most powerful, architectural design software available, we realize that some of our users value the added convenience of specialized training. With that in mind, the SoftPlan training programs, including the Authorized Training Classes, Live Online Training, and the Interactive Trainings DVDs were designed by our very own technical support staff.
Training.html
Training-Class-Samples.html
v14features_symbols_tropical.htm
v14features_edit_item_cleanup.htm
v14features_cabinets_two_drawer.htm
2012_Type-Erase.html
Type Erase All Items Added All Items can be easily removed from the drawing by selecting this option from Type Erase. ...
v13features_type_erase.htm
Type Erase Items Added to Type Erase: Take Off, Layers, Building Options, Posts, Area Schedules, Electrical Legends, General Tables, Opening Schedules, Room...
v14features_type_erase.htm
Type Erase Improved Version 12 has greatly improved the Type Erase Function. New Groups have been added and several new selections have been added to other groups. New Groups: Break Lines Cabinets...
typeerase_improved.htm
v14features_posts_type_erase.htm
v14features_SoftView_type_erase.htm
v14features_symbols_details.htm
Under-which-operating-systems-will-SoftPlan-run.html
Undo-Added-to-SoftView.html
v14features_layers_unlimited.htm
Upgrade.html
SoftPlan Upgrade Price Listing
Upgrades.html
Upon-performing-a-cleanup,-my-overall-dimension-is-moving-so-that-it-overlaps-my-intermediate-dimension-strings.-How-do-I-prevent-this.html
v14features_modes_footing.htm
Using-Adjust-Item-to-lengthen-a-wall-to-intersect-with-another-wall-often-redisplays-the-adjusted-wall-as-angled.html
Using-solids,-I-have-created-a-special-3D-post.-How-do-I-add-this-post-to-other-drawings.html
Using-the-Enter-Surveyors-Coordinates-My-Site-Lines-Will-Not-Draw.html
v14features_roof_valleys_intersect.htm
v14features_symbols_vents.htm
Version-11.html
Version-11_features.html
Version-12.html
Applyy these pataches to make your SoftPlan installantion current.
Version-12-upgrade.html
Version-13.html
Version-13-upgrade.html
Version-14.html
Version-14-Patches.html
Version-14-Major-Features.html
Version-14-Feature-Movies.html
Version-14-Features.html
Version 14 Quotes by SoftPlan Users
quotes_v14upgrade.htm
SoftPlan Version 14 Pricing
pupgrade.htm
v14features_symbols_visible.htm
Visible Items Deck Outline Option Added to Visible Items Display a simple deck outline by turning on the Deck Outline option under the Visible Items menu. This will...
v13features_visible_items.htm
Visible Items Display Print Pen Style Option Added The line weights that SoftPlan will print items with can be displayed on the drawing using the...
v14features_visible_items.htm
v14features_walls_beam_profile.htm
v14features_walls_utilize_profile.htm
Wall-Definition.html
Wall-Definition-How-to-Create-a-2x4-Stone-and-Stucco-Wall-Type.html
Wall-Framing.html
Wall Framing Label SoftPlan Version 12 has added the ability to now configure the Wall Framing Label display of a generate wall panel drawing. You are able to select between Width & Depth, Depth...
wallframing_label.htm
2012_Features_Wall-Framing.html
Wall Framing Add Header Command Added This command is used to place a single header over multiple openings. ...
v14features_wall_framing.htm
Wall Framing Add Plate Under Header Option Added A new Framing option for ‘Add Plate under Header’ is available to automatically add a plate between the header and...
v13features_wall_framing.htm
Wall-Framing.html
v14features_wall_join_zero.htm
v14features_wall_join.htm
Walls.html
Walls Dimensions Ignore Walls in Floor System, Ceiling, and Roof Modes Extension lines can be drawn from walls while in Roof, Floor System, and Ceiling modes. This...
v13features_walls.htm
Back | Print
Walls_support_FAQ.html
Walls 6" Concrete Wall Definition Added to Lite Banding Finish Options Added When drawing banding, a list of default...
v14features_walls.htm
2012_Features_Walls.html
Hidden Walls Have Closed Ends SoftPlan Version 12 has improved the Hidden wall display. Hidden walls are used when the wall is not required to be visible on a printout of the floor plan, but may be...
wall_hidden.htm
v14features_visible_items_walls.htm
v14features_electrical_weather.htm
What-are-heightmaps-and-how-are-they-used.html
What-are-the-optimum-settings-for-plotting-text-using-an-older-style-pen-plotter.html
What-are-the-settings-for-a-Shed-Roof.html
What-Can-You-Tell-Me-About-SoftPlan3D.html
What-determines-which-item-is-going-to-move-with-a-wall-that-is-being-moved.html
What-do-I-do-when-I-get-the-message-Your-activation-period-for-SoftPlan-is-about-to-expire.-If-you-do-not-arrange-for-additional-activation-time.html
What-does-the-warning-The-top-of-the-header-is-set-above-the-underside-of-the-top-plate-mean-and-how-do-I-correct-it.html
What-if-He-Site-Plan-Will-Not-Fit-Inside-the-Workspace.html
What-if-I-Cannot-See-My-Entire-Site-Options-Menu.html
What-if-I-have-enlarged-my-fonts-in-the-Character-Setup-but-some-of-my-notes-did-not-update-to-the-new-size.html
What-if-I-receive-the-error-message-Error-100-The-SoftPlan-Key-device-driver-has-not-been-installed-on-this-system.html
What-if-my-intermediate-dimensions-do-not-add-up-to-what-my-overall-dimension-is.html
What-is-a-Vertex-Point-and-How-Does-it-Differ-From-a-Shot-Point.html
What-is-SoftPlan.html
What-is-the-best-way-to-draw-a-Cape-Cod-Salt-Box-roof.html
What-is-the-difference-between-Drawing-Options-and-System-Options.html
What-is-the-Difference-Between-Opening-and-Importing-a-Review-(Spv)-File.html
What-is-the-difference-between-SoftPlan-and-SoftPlan-Lite.html
What-is-the-easiest-way-to-create-a-90-degree-staircase.html
What-is-the-Easiest-Way-to-Draw-the-Eaments-On-a-Site-So-That-They-Are-Parallel-to-the-Property-Lines.html
What-Kind-of-Output-Device-Do-I-Need.html
What type of video card does SoftPlan require?
We recommend a video card capable of supporting a minimum of DirectX version 10.1. To make sure you have the correct version of the DirectX driver installed, click here. While we do not have a specific minimum RAM requirement, the more memory on the video card, the better your graphics will be. Depending on the card, higher numbers of pixel shaders, vertex shaders, or stream processors will also yield better performance. Note that the video card does not affect the performance of SoftPlan’s Rendering mode.
SoftPlan runs well with the majority of the graphics cards recently released by NVIDIA and ATI.
Whoever the manufacturer of your graphics card, it is important to keep the video driver current. For more information, check the manufacturer’s site.
What-kind-of-Video-Card-does-SoftPlan-require.html
What-should-I-do-if-my-floors-don't-properly-align-in-SoftView.html
What-should-I-use-layers-for.html
Hardware Requirements
What-Type-of-Computer-Does-SoftPlan-Require.html
When-a-cleanup-is-run-what-determines-where-the-floor-system-items.html
When-drawing-a-wall-what-does-the-trace-line-represent.html
When-editing-the-roof-how-do-I-change-one-side-to-a-gable.html
When-generating-a-rendering-with-light-sources-and-ray-tracing-set.html
When-I-add-my-Opening-I-don't-see-any-fractions-in-its-size.html
When-I-add-my-openings-the-Opening-size-displays-and-I-would-like-the-Rough-Opening-or-Product-Code-to-be-displayed.html
When-I-add-railings-to-a-flared-or-curved-stair-in-version-12.2.0.html
When-I-add,-move-or-adjust-an-object,-SoftPlan-adds-extensions-and-dimensions.-How-can-I-stop-this-from-occurring.html
When-I-am-drawing-or-previewing-symbols-it-seems-to-take-a-while-as-I-move-from-symbol-to-symbol.-Can-anything-be-done-to-speed-this-up.html
When-I-Am-Drawing-Walls-and-Shapes-I-Notice-That-the-Command-Will-Stop-Why-Do-I-Have-to-Restart-the-Drawing-Process.html
When-I-am-drawing-walls-and-shapes-I-notice-that-the-command-will-stop.-Why-do-I-have-to-restart-the-drawing-process.html
When-I-attempt-to-add-paint-to-a-site-plan-why-do-I-get-a-message-that-the-area-to-paint-is-too-large-even-when-the-enclosure-is-properly-closed.html
When-I-attempt-to-dimension-between-walls.html
When-I-change-from-an-8-Concrete-Block-wall-to-a-10-Concrete-Block-wall.html
When-I-create-a-custom-Electrical-symbol,-how-do-I-get-the-green-reference-points-that-the-electrical-connections-attach-to.html
When-I-DXF-out-drawings-to-export-them-into-AutoCAD.html
When-I-generate-an-elevation-it's-displaying-the-openings-but-no-walls-How-do-I-correct-this.html
When-I-generate-the-roof-framing-as-a-drawing.html
When-I-installed-Version-13-it-did-not-prompt-me-to-enter-my-authorization-code.html
When-I-move-my-cursor-over-an-object-my-cursor-shows-a-symbol.-Why.html
When-I-open-a-project,-I-have-no-Navigation-or-Status-bar.-How-do-I-get-them-back.html
When-I-perform-a-cleanup-my-joist-sets-are-aligning-at-the-same-position-rather-than-staggering.-How-do-I-correct-this.html
When-I-print-a-Jpeg-(.jpg)-image-that-has-been-inserted-into-a-drawing.html
When-I-save-my-symbol-will-the-Paint-pattern-be-saved-as-part-of-that-symbol.html
When-I-start-my-HomeWork-Station-it-requests-a-key-number-and-registration-code.-Where-do-I-find-that-information.html
When-I-try-to-generate-a-cross-section,-why-does-the-following-message-appear-The-lowest-floor-in-the-assembled-floor-stack-does-not-have-a-secti.html
When-I-try-to-open-SoftPlan-Version-14-I-get-a-message-that-The-application-failed-to-start-because-the-application-configuration-file-is-incorre.html
When-I-try-to-open-Version-10-or-earlier-drawings-in-my-current-version-I-get-a-message-that-says-Version-10.2.html
When-I-try-to-open-Version-10-or-earlier-drawings-in-my-current-version-I-get-a-message-that-says-V-10.2-(or-earlier)-SoftPlan-key-has-not.html
When-I-try-to-select-the-Copy-to-SoftPlan-Clipboard-or-the-Paste-from-SoftPlan-Clipboard-commands.html
When-I-try-to-use-Auto-Dimension.html
When-importing-a.DWG-or.DXF-file-from-another-program.html
When-installing-SoftPlan-on-Windows-2000-with-Service-Pack-4-the-auto-run-fails-to-start-and-an-error-message-occurs.html
When-placing-joists-on-the-main-floor-plan-how-do-I-locate-where-the-beams-are-in-the-basement-plan-below.html
When-printing-from-the-Educational-WorkStation-the-watermark-is-repetitive-and-dark-on-my-drawings.-Is-there-a-way-to-lighten-the-watermark.html
When-printing-some-multi-drawings-in-version-12.2.0.html
When-printing,-do-the-drawings-refer-to-the-System-or-Drawing-options-for-their-pen-setting.html
When Running the SoftPlan Demonstration and Trial DVD I encounter the error: "This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem."?
When-running-the-SoftPlan-demonstration-and-trial-DVD,-I-encounter-the-error-This-application-has-f.-Reinstalling-the-application-may-fix-this-problem
When-scaling-the-drawing-to-print-I-cannot-see-the-entire-drawing-or-scaling-box.html
When-upgrading-from-an-earlier-Windows-version-of-SoftPlan.html
When-using-SoftPlan-in-Vista-when-I-import-my-Version-8-&-9-files-I-get-a-message-that-the-Conversion-Utility-has-Stopped-working.-The-drawings-a.html
Where-can-I-change-the-default-pitch-and-other-settings-that-are-used-to-generate-the-roof.html
Where-can-I-find-a-Windows-driver-for-my-older-pen-Plotter.html
Where-do-I-install-the-Master-Key-Manager.html
Where-do-I-install-the-SoftPlan-WorkStation-software.html
Where-do-I-save-System-Drawings.html
Where-do-I-set-up-dimension-and-extension-options.html
Where-do-I-set-up-the-pen-settings-for-Walls.html
Where-is-the-Elapsed-Time-feature.html
Where-is-the-offset-of-a-post-and-pad-measured-from.html
Which-code-should-be-selected-when-exporting-from-SoftPlan-to-REScheck.html
Which-do-I-draw-first-the-roof-or-the-roof-framing.html
While-attempting-to-add-a-symbol-I-receive-an-error-message-that-the-maximum-number-of-different-symbols-has-been-reached.-What-should-I-do.html
While-attempting-to-draw-a-line-on-top-of-another-item.html
While-Attempting-to-Perform-an-Edit-of-a-Window-the-Program-Keeps-Selecting-the-Wall-How-Do-I-Fix-This.html
-D3dx9_35Dll-Was-Not-Found
While-Using-the-Demo-DVD-I-Experience-the-Following-Warning-When-Going-Into-3d-Application-Has-Failed-to-Start-Because-D3dx9_35Dll-Was-Not-Found.html
Why-are-my-1-8-increment-fractions-not-displaying-or-not-displaying-correctly-on-screen-or-when-printed.html
Why-are-my-drawings-missing-textures-when-I-load-a-Version-12-material-file.html
Why-are-my-mouse-navigation-controls-not-working-in-SoftView-3D.html
Why-are-my-symbols-printing-solid.html
Why-Do-Drawings-I'Ve-Imported-From-Version-9-Appear-with-a-Black-Background-Instead-of-Their-Original-White-Setting.html
Why-do-I-have-a-Horizon-between-my-First-and-Second-Floors.html
Why-do-I-have-two-keys-for-my-Educational-installation.html
Why-do-I-no-longer-see-any-eighths-fractional-characters-on-screen-since-installing-the-13.4.0-patch-file.html
Why-do-I-not-have-the-product-code-for-the-door-when-I-draw-it-with-a-right-hand-swing.html
Why-do-I-not-see-interior-elements-in-SoftView-3D-such-as-Chair-Rail-or-Crown-Mold-or-Flooring-etc.html
Why-do-I-seem-to-be-missing-details-on-my-cross-sections.html
Why-do-my-plot-files-have-a.prn-extension.html
Why-do-my-symbols-jump-to-the-outside-of-the-walls.html
Why-do-the-openings-I-create-not-show-glass.html
Why-does-a-box-sometimes-appear-in-place-of-my-small-dimension-numbers.html
Why-does-a-gap-appear-between-my-Main-Floor-and-Foundation-in-SoftView.html
Why-does-a-Rotated-Cross-Section-or-Elevation-take-a-long-time-to-save.html
Why-does-a-Rotated-Elevation-or-Cross-section-take-a-long-time-to-save.html
Why-does-my-3D-model-switch-over-to-Wireframe-mode-when-I-do-a-walkthrough.html
Why-does-SoftPlan-dimension-to-lines.html
Why-doesn't-a-border-I-created-in-Version-9-work-in-a-newer-version.html
Why-doesn't-my-plan-show-up-in-Roof-mode.html
Why-doesn't-SoftPlan-have-product-codes-for-Milgard.html
Why-don't-my-short-walls-clean-up-properly.html
Why-has-my-default-font-reverted-to-a-different-font-(Arial-or-Marlett)-I-can't-seem-to-change-it-back.html
Why-is-3D-slower-to-generate-when-I-have-Electrical-Symbols-drawn.html
Why-is-generating-a-3D-model-slow.html
Why-is-My-Cursor-Jumpy.html
Why-is-my-gable-end-window-not-showing-in-3D.html
Why-is-my-HP-Design-Jet-600c-omitting-some-text-on-prints.html
Why-is-my-roof-cross-section-not-as-detailed-as-I-thought-it-would-be.html
Why-is-the-Review-Selection-Grey-in-Color-and-Not-Selectable.html
Why-is-there-no-3-Dimensional-information-in-the.dxf.dwg-file-that-I-imported.html
Why-when-drawing-symbols-does-it-takes-a-while-for-the-3D-preview-to-display-in-the-Draw-Symbol-Dialog-Box.html
Will-SoftPlan-benefit-from-a-dual-core-processor.html
Will-SoftPlan-run-on-the-Windows-XP-Operating-System-with-Service-Pack-3-installed.html
