Adjustment of Box Shapes
SoftPlan Version 12 has modified the
Adjustment of Box Shapes. When such a shape is adjusted, the sides
perpendicular to the edge being adjusted will display as the box expands /
contracts. This enables an improved visual feedback of how the shape is
being adjusted. This feature was previously unavailable in earlier
versions of SoftPlan.
In SoftPlan select Draw >
Shape > Box.
Draw a box in
the SoftPlan drawing area.
Select Move
> Adjust Item.
Click on the
edge of the box you would like to adjust.
Move your
cursor to define the extent of how you would like the box
adjusted.
Note: As you
move your cursor you will see the edges of the box perpendicular to the edge
you have selected adjust along with that edge. This gives a clearer view of the
extents of the box as it is being adjusted, in turn allowing you to be more
accurate when defining the shape.
Cleanup Automatically Combines Collinear Lines
SoftPlan Version 12 has added a new
feature that will automatically combine two or more collinear lines into a
single line upon hitting Cleanup. Often when Elevations and Sections are
saved as SoftPlan Drawings, several lines from different items are created
on top of each other. A Cleanup will now join these lines assuming they
have the same properties such as linestyle, scale, texture and color. This
will optimize the drawing allowing it to be more easily edited and
modified. Collinear lines that do not have the same properties are not
combined.
Radius of an Arc can be Adjusted
Using the command
Move > Adjust Item allows for the radius of an arc to be adjusted on both
shapes and solids. Previously selecting an arc would snap the cursor to the
endpoint, thereby only allowing for the adjusting of the sweep. This will allow
for greater latitude of sketching and later modifying of shapes and solids in
SoftPlan.
- Select Move > Adjust
Item.
- Select along the arc, staying away
from either end point.
- As the cursor is moved, the arc will
adjust with it.
- Click the button to
complete.
Note:If it is the sweep of the arc
which is to be changed, select the endpoint and SoftPlan will hold the
radius, while allowing for the arc to be adjusted.
Cursor Relocate
When selecting an item to Move, the
Cursor will relocate to the line rather then the line relocating to the
Cursor. This makes it easier for items to stay aligned on the drawing.
Previous versions of SoftPlan would have the item move to the
cursor.
- Draw a line about 10’ long on the
screen and click on the zoom extents icon.
- Place the cursor close to the line
but not on it. Without moving the mouse, click it. The cursor will
relocate to the line.
Solid Texture can be Assigned to Circles
ability to now add a Solid Texture to Circles. This allows you to draw any
circle-based shape, edit its properties, and change the texture to a solid
texture. This feature was previously unavailable in earlier versions of
SoftPlan.
- Select Draw > Shape >
Circle.
- Once you select the Circle option,
you will have a choice of selecting one of the various circle-based
shapes. Circle, Oval, Pentagon, Hexagon, or Octagon.
- Select Circle >
Center.
- Click on your screen to define the
center point of the circle. Drag your cursor to define the radius, and
click again to complete the circle.
- Select Edit > Edit Item. Click on
the circle you had drawn.
- From the Circle edit menu that
appears, click on the Texture selection field to display the available
textures. Select the Solid texture available. Click OK.
Half Sphere Solid Added
Version 12 of SoftPlan has expanded
the list of primitive solids to include the Half Sphere. It can initially
be drawn as a circle or as an oval in plane. The Half Sphere can then be
edited for appropriate size and be given a Height, which can then be
represented in SoftView 3D.
Select Draw > Solid >
Half Sphere > Circle > Solid 1.
Click to indicate the center
location of the Half Sphere.
Click again to indicate the
radius of the Half Sphere.
Using Edit > Edit Item you
can modify the properties of the Half Sphere.
Line Style Scale Factor Added
SoftPlan Version 12
has introduced a scaling factor for dashed line textures and the Solid items of
Arc Plane and Plane. This can be used to make the dashes and gaps that are in
the line texture larger or smaller.
- Draw several lines that have a dashed
texture to them.
- Go to Edit > Edit
Item.
- Click on one of the textured lines,
checkmark the ‘Style Scale’ box and enter a new scaling
factor.
- This feature
allows dashed lines to appear dashed when printing at different
scales
Half Cylinder Horizontal and Half Cylinder Vertical
Added
ability to draw a solid Half Cylinder in both a horizontal and vertical
position, for use in 3D. The half cylinder can also be drawn as a wedge
portion of a full cylinder, or a slice portion.
Half Cylinder Horizontal -
Slice
- Select Draw
> Solid > Cylinder > Partial > Horizontal.
- Once you have
selected the Horizontal style, you will need to choose between a Slice or a
Wedge.
- Select >
Slice > Solid 1.
- Click on your
screen to begin drawing the Half Cylinder. Create an expanding box to
define the length and width of the cylinder, and click
again.
- The cylinder
will be drawn, showing with a dashed line the extent of the half cylinder
curve. Editing the cylinder at this point will allow you to the start
point, and the sweep angle of the cylinder. In a slice, the arc is drawn
the length of your sweep angle, and the start point will be connected to
the end of the arc, in turn creating a slice.
Wedge
- Select Draw
- Once you have
Wedge.
- Select >
Wedge > Solid 1.
- Click on your
again.
- Click on your
again.
- The cylinder
point, and the sweep angle of the cylinder. In a wedge, the arc is drawn
the circle center point first, and then to the end of the arc, in turn
creating a wedge.
Half Cylinder Vertical –
S-E-(R)
- Select Draw ?
Solid ? Cylinder ? Partial ? Vertical.
- Once you have
selected the Vertical style, you will need to choose between an S-E-(R) or and
S-C-(L) cylinder.
- Select ? S-E-(R) ?
Solid 1.
- Click on the
screen to begin drawing the S-E-(R) arc. Move your cursor across the screen to
define the chord length and click.
- Next, move your
cursor perpendicular to the chord to define the amount of deflection and
click.
- The cylinder will
be drawn, using both the chord length you had defined, and the arc deflection,
to completely enclose the cylinder.
Half Cylinder
Vertical – S-C-(L)
- Select Draw >
Solid > Cylinder > Partial > Vertical.
- Once you have
S-C-(L) cylinder.
- Select ? S-C-(L)
> Solid 1.
- Click on the
screen to begin drawing the S-C-(L) arc. Move your cursor across the screen to
define the radius length and click.
- Next, move your
cursor perpendicular to the radius line to define the arc length of the
cylinder.
- The cylinder will
be drawn, using both the radius length you had defined, and the arc length, to
Board End has Separate Pen Assignments for Outline and
Texture
Version 12 has improved Board Ends,
the Outline and Texture lines have separate pen assignments.
Changing the pen
assignments can be used the emphasis on an item or make it clearer on the
print out.
Load a Cross Section, or
another drawing that contains a Board End, in SoftPlan.
Click on Edit
> Edit Item.
Click on a
Board End.
Polygon Added
Among the new drawing tools for
Version 12, Shape – Polygon has been added. This allows for a free-form
sketch, or exact sketch of a custom shape containing three sides or
more.
- To draw a shape polygon go to
Draw> Shape> Polygon.
- Trace the complete perimeter of the
polygon starting at one point and closing the loop back at the start
point. To do this, use the polygon tracing method to enclose the
area.
Dashed Line Styles Start and End with a Dash
SoftPlan Version 12
has improved the presentation of dashed line styles by ensuring that the start
and end points of the line are drawn with a full dash. In previous versions,
dashed line styles could potentially have ended with a shorter dash, or even a
space and thus appearing slightly shorter that what it actually was, as seen in
the illustration.
| To see this applied to basic
Lines: |
Line
- In the Status bar select one of the
Dashed Line Styles available.
- Drawing the line will now ensure that
the start and end points of the line are drawn with a full dash,
regardless to the length of the line.
| This new feature applies to all Shapes,
Solids, Site Lines, Walls and Beams defined with a dashed line
style. |
