Adding of Gable Ends on Multiple Floor Roof Improved
Improvements have been made with
regard to the way that Gable ends on a roof are recognized and extracted
in a Multiple Floor roof situation. When assembling floor plans using the
Multiple Floor roof feature, the lower floor in the assembly now has it’s
data stored into an upper floor drawing containing the roof. This ensures
that the gable ends that reference walls of a lower floor plan continue to
recognize the bearing walls or beams position and therefore extract
correctly in SoftView 3D. If the Multiple Floor Roof becomes unchecked,
then the lower plan will no longer be stored and will have to be
reassembled with the upper plan to regenerate the roof.
The Lower Floor Plan of a Multi Floor Roof is Saved on
Screen
Multi Floor Roof has been improved
with Version 12, the lower floor plan will be saved on screen and does not
need to be selected each time.
Go into the upper floor of a
two story building and go into Roof mode.
Select Multiple Floor Roof and
choose the lower floor.
Add the roof and save
it.
Exit SoftPlan.
Enter SoftPlan again and load
the upper floor again. It will automatically bring in the lower
floor.
Note: If you go end
the Multi Floor roof feature and save it, the lower floor will not be saved on
screen the next time the upper floor is taken into roof mode.
Gable End Provided by Roof will Appear in Roof Mode and will not
Version 12 has added a new display for
the Gable End provided by Roof.
- In the Roof mode, Edit a Gable roof
edge (Edit> Edit Item).
- When the option Gable End Provided by
Roof is selected, a construction line appears along that roof edge. When
not selected, it turns off.
- This construction line will not print
and is for display purposes only.
Profile Renamed to Roof
Profile in Roof Mode
In Version 12 the option for
generating the Roof profile has been renamed. In Roof mode, under the Draw
menu it is now called Roof Profile. In Version 11 it was simply named
Profile, which was mistaken for Wall profiles. The Roof profile will only
generate the roof components.
| Image 1 shows the Version 11menu. Image 2
shows the Version 12 menu. |
Gable End Trusses Locate the Outside Bearing Edge of
Studs
Version 12 will snap the Gable End
Trusses drawn on a roof to the bearing edge of a gable end
wall.
To do this, open a plan that
contains a gable end within Roof Mode.
Go to Draw> Framing>
Gable End Truss.
Draw the Truss to span the
gable end. Starting at one edge, click to indicate the start point
of the truss, then run the cursor to the opposite roof edge and
click.
If the Truss is within the
tolerance of the bearing wall edge, then the truss will snap to
the edge of the wall. Also, if the Gable End Truss is within the
tolerance of the gable end wall and a cleanup is performed, this
will snap the truss to meet the wall edge.
Auto Hole Command Improved
Version 12 has improved the Auto Hole
command, this feature can be used to cut a hole in a Roof on Bay. To use
Auto Hole to cut a hole in the roof under the roof under the
bay:
Load a drawing that has a roof
added to it using the Roof on Bay feature.
- Select Draw > Hole > Auto
Hole.
- Click on the overlapping area of the
bay roof and the main roof in the roof plan.
Skylight Command Added
Version 12 is now able to draw
Skylights in Roof mode. Previous versions of SoftPlan did not have a
skylight function.
- In roof mode, click Draw >
Skylight.
- Click on the roof that you want to
add the skylight to and form an expandable box to draw the
skylight.
To Form an Expanding
Box:
- Select the command you
need.
- Place the cursor where you want to
begin to draw the expanding box, and then click.
- Move the cursor to form the box shape
and size you need.
- Click to complete the expanding
box.
The Skylight function will do
several things:
- Automatically detect the slope of the
roof.
- Automatically cut a hole in the
roof.
- Automatically appear in SoftView,
Elevation, 3D, and cross section.
- With the visibility turned on,
Skylights will also show in Drawing
Auto Regenerate Option Improved for Roofs
SoftPlan version 12 has improved the
Auto Regenerate option for roof sections. As the floor plan design
changes, existing roof surfaces will adjust to accommodate new wall
locations and wall heights. After the desired floor plan changes are
complete, a Cleanup performed in Roof Mode will then regenerate all
affected roof surfaces without the need to erase and redraw the roof
sections.
Image 1 shows the original roof lines,
but the floor plan has changed size. The wall heights for the rear projection
were increased, as well as the rear wall moved back further. The left side of
the home was made wider. The front left room was made larger and the garage
are on the front right was also made larger.
Image 2 show the new roof lines after
a cleanup was performed. The automatic regeneration of the roof accounted
for all changes made to the floor plan and adjusted the roof design
accordingly.
Double Hip Roof Formation of Gable Ends Improved
SoftPlan version 12 has improved how
the Gable ends of Double Hip roofs appear in SoftView. The Double Hip roof
style can be used to achieve a Gambrel style roof if adjacent gables are
added. Version 12 will now appropriately draw the fascia on the gable ends
of Gambrel style roofs for a more accurate looking 3D image and automatic
Elevations.
Bird's Eye Roof Plans Save in Their Original Plan
Location
An added feature of SoftPlan Version
12 is the ability for generated Bird’s Eye roof plans to save in the same
plan location as the original floor plan. The Bird’s Eye command in Roof
Mode allows a line drawing to be created of the roof edge, hip, valley and
ridge lines, used to create Roof Plans. Previous versions simply centered
the new Bird’s Eye drawing in the middle of the workspace, but now version
12 saves the Bird’s Eye drawing in the same position as the original roof
it was generated from. This make is much easier to place the generated
Bird’s Eye roof plan on top of the original floor plan when you want to
display the roof outline on your working drawing of the floor plan. You
simply need to merge the Bird’s Eye roof plan with the Floor Plan and the
two drawings will automatically align with each other.
Open a floor plan drawing that
contains a completed roof design.
Switch to Roof Mode from the
Mode Selector in the Status bar to view the roof.
Select Draw > Bird’s Eye to
generate a bird’s eye view of the roof.
Save the Bird’s Eye drawing as
Roof Plan.spd and then exit SoftView
Back in the floor plan, switch
back to Drawing Mode.
Select File > Merge and
then select the saved Roof Plan. When merged, the roof plan lines
will be appropriately positioned around the floor plan.
