Back | Print
SoftPlan reView Frequently Asked
Questions
Is there a charge for SoftPlan
reView?
The SoftPlan user that is going to author or publish the reView file
will be required to purchase an additional module, SoftPlan reView. The viewer portion of SoftPlan reView can
be distributed free of charge.
Will I be able to import my customer’s comments and markups
back into my SoftPlan drawing?
Yes, any information such as comments or sketches that your customer
makes on the reView file will import back into the original SoftPlan drawing.
Will SoftPlan reView run on my Palm hand-held
device?
At this time reView requires a Windows PC or a Pocket PC to run the
reView viewer and will not run on a Palm operating system.
I currently send my designs to customers using a .PDF file
format. Why would I use SoftPlan reView instead?
reView maintains all the “architectural” information contained in the
original SoftPlan file. So not only can you see the floor plan or elevation but you will know the size of the
window or the height of the wall. A .PDF file on the other hand is more of a representation of a piece of
paper.
I use SoftPlan Version 11, can the reView module be added to
my SoftPlan?
No, SoftPlan reView requires at least SoftPlan Version
12.
Will my field personnel be able to see all of the drawings on
a hand-held?
Yes, any SoftPlan drawing can be published as a reView file. So floor
plans, elevations, details, and site plans will all be available for viewing on any Pocket
PC.
Is reView suitable for the creation of existing conditions
drawings? Can I walk around an existing building and enter it into reView?
No, reView is intended to view, annotate, and query technical drawings
created in SoftPlan. Regular SoftPlan running on a tablet or laptop PC would be much better suited for the
creation of drawings.
Can the framing diagrams for my houses be viewed in
reView?
Yes, reView has the same modes as SoftPlan. To view the roof framing
for example, open the floor plan and switch to roof mode, then the roof framing layout complete will
display.
Will my clients be able to print the reView
drawings?
Yes, but it is up to you. When the reView file is created the author
decides if the resulting file will print or not. If printing of the file is allowed, then the author decides
if the user can print it to scale or only to fit the page.
I have SoftPlan Lite will I be able to purchase the SoftPlan
reView module?
No, SoftPlan reView can only be added to the full SoftPlan
program.
Why would I use SoftPlan reView to send drawings to my print shop
rather than .PDF files?
SoftPlan reView files are much smaller, roughly 10% of the size, so
the files are easier and faster to transmit.
I have a client that prefers .PDF, files how can I create .PDF
files?
In addition to creating reView (.SPV) files, SoftPlan reView can
author .PDF files.
I have an older Windows CE device, will SoftPlan reView run on
it?
reView requires the operation system on the hand-held to be at least
Pocket PC 2003 (sometimes referred to as Pocket PC Version 4). Older operating systems, Windows CE or Pocket
PC, are insufficient.
How can my customers access the SoftPlan reView
Viewer?
The SoftPlan reView Viewer can by selecting the link at the bottom of
this page and is also located on the SoftPlan installation CD in the SoftPlan reView
folder.
Can SoftPlan reView be downloaded directly to a Pocket PC
device in order to install it?
No, the installation program must be downloaded to and run from a PC
which is connected to the Pocket PC device via Microsoft ActiveSync®.
Why send a reView file instead of a
.PDF?
The advantage of a reView file is the ability to right click on a
wall, symbol, window, etc., and get a description of the item’s properties. For example, right clicking on a
wall will show the wall style and height. You can also run a cursor from one line to another to get the
distance. This is a huge benefit to the client or engineer because they can instantly see the information.
You can also link comments from the person who gave the comment so the person viewing the file can see who
made the comment.
Can you mark-up and add notes to the different modes in a
reView file?
Yes, the reView viewer allows clients to make mark-ups and notes in
all of the modes available in SoftPlan. This keeps the notes organized in one file instead of different
sheets in a .PDF. The mark-ups made in any mode will be displayed in that mode when the drawing is brought
back into SoftPlan, and the mark-ups will appear in the reView mode. This feature also offers a lot of
flexibility to the person exporting the review files. Visibilities and screen colors of items can be set up
anyway you want for each of the different modes using Visible Items, Layers, or Building Options. Besides
obvious options like a plumbing or HVAC mode, you can separate dimensions, furniture layouts, etc. from the
main drawing mode if desired. This allows clients an uncluttered view of the floor plan, but still gives them
access to other information.
Will SoftPlan reView run on my BlackBerry hand-held
device?
reView viewer and will not run on a BlackBerry operating system.
Back | Print
