Earth Pattern and Wood Grain Pattern Added
SoftPlan’s Paint pattern libraries
have been expanded to include both an earth and a wood grain pattern.
Click below to view an example of these patterns.
Select Draw > Paint >
and the respective library to add.
Paint Magnification can be Input From the Keyboard
Version 12 now has the ability to
manually input the value for paint magnification by using the keyboard. In
previous versions the scroll buttons needed to be used to select a
value.
To adjust the magnification of paint select.
Edit > Edit
Item.
Click on the
paint pattern.
Click in the
magnify field for horizontal or vertical and type in the value using
the keyboard.
Press
OK.
The paint
pattern will automatically update on screen.
Paint Patterns May Contain Arcs and Circles
Version 12 has improved the Paint
feature by allowing the original paint pattern to be created using arcs
and circles with a smaller radius. Previous version of SoftPlan also
allowed arcs and circles to be used in paint patterns but their radius
needed to be much larger for the paint to appear intact when used in a
drawing.
To create a Paint
pattern:
- Select Draw > Paint > Paint
Definition Template and sketch a box approximately 1’ x 1’.
- Select Draw > Shapes > Circle
or Arc and create the desired pattern inside the template. The diameter
of the circles and arcs can now be as small as 2”.
- Edit the Paint Definition Template
and select the Add Pattern button.
- Choose a Paint library and give the
pattern a name.
| To draw the Paint
pattern: |
- Select Draw > Paint and select the
desired Library and pattern.
- Left click in the area on the drawing
you wish the pattern to fill. The small radius circles and arcs will now
maintain their original appearance more accurately than in previous
versions.
Paint Patterns May Contain Textured Shapes
Version 12 has improved the ability to
create custom Paint patterns by allowing shapes to maintain Textures that
have applied to them. Additionally, a shape given a dashed Linestyle can
also be used to create a Paint pattern. In previous versions, if a shape
had a dashed Linestyle or Texture applied the Linestyle and Texture would
have been ignored and the only basic shape would have been used to create
the Paint pattern.
Paint Definition Template to be used as a canvas to create the new
paint pattern.
Select Edit > Edit Item and
edit the Paint Definition Template to the size of the repeating
pattern.
Select Draw > Shape >
and select a shape to be used to create the paint pattern.
In the Status bar, select a
Dashed Linestyle or Texture to be applied to the line.
Draw the pattern in the
template. As the pattern is drawn, it will be repeated around the
template to help in previewing the pattern’s overall
design.
edit the Paint Definition Template again and select Add Pattern to
add the new paint pattern to the Paint Library.
Once the pattern is added,
select Draw > Paint > select the new pattern and click into
an enclosed area of the drawing to fill with the new paint
pattern. The Linestyle and Texture are maintained when the paint
is applied to the drawing.
| This applies to all Linestyles and
Textures except for the solid fill texture. |
The Paint Template Acts as a Knife Blade for Trim and a Boundary for
Extend
SoftPlan Version 12 has the ability to
now use the Paint Definition Template as a boundary edge for the Trim
and/or Extend command. This eliminates having to use “extra” lines as
boundary edges when creating your paint patterns.
Definition Template.
- Click once to
begin your template box.
- Drag the cursor
and click again to complete the template.
At this point you can proceed with
creating your paint pattern within the template you had defined. If any of
the items partially fall outside of the template edge, or do not quite
meet the template edge:
- Select Tools > Trim or
Extend.
- Click on the edge you would like to
use as the Trim or Extend edge.
- Click on the item to Trim or
Extend.
- Once the item is selected, it will be
trimmed or extended to the edge of the paint definition template you had
selected, and the paint pattern display will update to show the
correction made.
Paint Patterns Avoid Opening Dimensions
Paint patterns will now avoid painting
over Opening Dimensions, much as they do for Dimension numbers. Previous
versions of SoftPlan would paint over the opening Dimension.
