Quoins and Corner Boards Will Display in Plan View
SoftPlan Version 12 has expanded the
option of display Quoins & Corner Boards in plan to also include any
exterior trim and/or keystone which may be added to an opening to appear
in plan. Previously this setting only allowed for the display of Quoins
and Cornerboards.
- Select File > Drawing Options >
Material Dimensions > Trim Options.
- Place a check mark next to the
“Display Quoins and Corner Boards in Plan.”
- Select Ok to return to the
drawing.
Openings can be Copied Along a Wall
The Copy feature has been improved in
Version 12. It can now copy an opening along the same wall. Previous
version of SoftPlan would not allow an opening to be copied.
- Once you have an opening added to a
wall, edit the opening to make any changes you require.
- Click Move > Copy.
- Click on the opening and move along
the wall in the direction you want the opening copied.
- Click again and enter the number of
copies you would like.
Move can Relocate Openings in Curved Walls
Version 12 has
improved Openings so that Move is able to Relocate them along the Curved Wall.
Previous versions of SoftPlan did not allow openings to be Moved along a curved
wall.
Load a drawing that has an
opening in a curved wall. Click on the Move icon.
Click on the opening and it
will move it along the curved wall.
Click your mouse again to
place the opening.
SoftView Check Box Added
SoftPlan’s Opening edit properties now
include an option to exclude an opening from SoftView. This option will
now allow for an opening to be drawn in plan, however in SoftView, this
opening will not be shown. This should greatly assist with remodel
designs, where an opening to be removed needs to be displayed in plan, but
not in Elevation, Cross Section or 3D.
Pocket Doors Draw Partially Open
ability to now display Pocket Doors with the operable leaf partially open.
In previous versions Pocket Doors were shown closed.
- Select Draw > Opening > Pocket
Door.
- Select any of doors available to you
from the Pocket Door library.
- Place your cursor in the wall you
would like the door placed and click.
- Move your cursor in the direction of
the door and click.
- Move your cursor to designate the
outside face of the door and click.
· Softplan will place the selected
Pocket Door in the wall location you have designated, showing the door itself
to be partially open.
Moving Openings Using Move Block
ability to now move an opening along a wall using the Move Block feature.
This could then allow you to move a group of openings in a wall, without
having to individually move or reposition each one.
In order to demonstrate this feature,
you will need to have a drawing open which contains openings. If you do
not have a drawing created, open one of our provided sample drawings to
use.
- Select Move > Move
Block.
- Click once to begin an expanding
box.
- Move your cursor to create an
expanding box around the opening, or openings you would like to move.
Click again to complete the box.
- Using either your mouse, or your
keyboard functions, move the openings to the desired
location.
- Click again to complete the
command.
- SoftPlan will move all the openings
encompassed by the expanding box to the new location you have designated.
All related dimensions and extension lines will be repositioned to the
new opening location as well.
Align Opening Tops Command Added to Edit Menu
The Edit menu now contains "Align
Opening Tops". This command moves the top of the target openings to the
same position in the wall as the top of the source opening. This command
will expedite the process of aligning openings quickly on a plan which
contains multiple walls heights, but needs to top of some or all openings
to match.
For this example, the front elevation
contains 3 different plate heights of 8-0”, 9’-0” and 10’-0”. With all of
the openings having an offset of 12.5” from the top of wall, their
vertical placement is staggered across the front.
- Select Edit > Align Top of
Openings.
- Click the front entry doors which
will grab the top of opening measurement.
- Select Ok to close the Opening
menu.
- Proceed to click on each of the
openings to align.
Drywall Wraps Around to the Frame When Opening Interior Trim is
Removed
Improvements have been made to the 3D
interior view of openings. For instance, when the Interior trim display
is removed from an Opening, the drywall surface now extends to the frame,
creating a wrapping effect to fill in the wall. This fills in gaps that
would otherwise be exposed around the frame.
- Image 1 shows the opening that
includes the interior trim. The interior trim covers the drywall surface
of the wall.
- Image 2 shows the opening that does
not include the interior trim. The drywall extends to cover the wall
surfaces that display after having removed the trim.
Product Codes Include a Pre-Hung Option
An added improvement to Door Openings
in SoftPlan Version 12 is the inclusion of a “Pre-hung” option. This
feature, when left unchecked, allows a door’s Product Code designation to
be maintained regardless of the Hinge that is specified. This addition to
the openings will benefit the users who wish for a door’s product code
designation be maintained whether the same door is drawn with a
left-handed swing or a right-handed swing. Previous versions of SoftPlan
assumed all doors to be Pre-Hung, and thus all interior doors required a
LH and RH opening to be defined in order for the Product Code to be
maintained.
- Select File >
System Library to open the Configure Library dialog.
- Change the Library
type to Openings.
- Select the + sign
beside the Colonial Door Interior library to expand the list and display all
the interior doors.
- Highlight one of
the doors and select the Edit button to open the Configure Opening
dialog.
- Select the Edit
Individual Component button to open the Opening Component
dialog.
- To allow a door to
maintain its Product Code designation regardless of its swing, uncheck the
Pre-Hung option.
- Select OK to close
all dialogs.
- In an existing
drawing with interior walls drawn, select Draw > Openings > Colonial Door
Interior and locate the door that was modified.
- When drawing this
door, it will maintain its Product Code option regardless of the way the door’s
swing is orientated. If the opening is set to display it’s Product Code as the
Opening Text, the door will always be appropriately labeled.
When a door is specified as a non
Pre-Hung opening, the Hinge Side option in the opening’s Edit dialog
becomes a checkbox labeled Reverse Hinge Side rather than an edit field
where the hinge is specified (L for Left, R for right). To make a non
Pre-Hung door swing on the opposite side, simply check this
option.
Opening Outlines Display in Profile Mode
SoftPlan Version 12
has modified how the Profile Mode now displays openings that have been placed
in the Floor Plan. Openings will now display as an accurate outline
representing the shape of the opening used. This feature is best
demonstrated when using openings that are irregular shapes (Arched, Round,
Oval, etc.).
Add an irregularly shaped
opening to a drawing, or find an existing irregularly shaped
opening on your drawing.
From the Mode
Selection list select Profile.
The SoftPlan
Profile mode will now display the exact outline of your opening shape
as was placed in plan. This allows you to check items within the
Profile mode, and know which type of openings have been used in the
drawing.
Opening Schedule can Save Default Column
Specifications
SoftPlan version 12 has improved the
ability to create automatic Opening Schedules by allowing the default
column specifications to be saved. In previous versions the program
defined the default columns and the user had no option to save any
changes to the column specifications. Now you can select which columns
are to be included as the default, eliminating the need to continually
select which columns to include or exclude for each Opening Schedule
added to your drawings. You are also able to select which opening types
are too be included or excluded by default in the Opening Schedule, again
eliminating the need to manually select the opening types each
time.
- Open a sample drawing containing
openings.
- Select Notes > Opening
Schedule.
- Click on the drawing area where you
wish to insert the schedule.
- From the Fields Included in Table
section, select the fields you want to Include or Remove from the Opening
Schedule.
- From the Opening Types section,
select the opening types you want to Include or Remove from the Opening
Schedule.
- To save the selections for use on
future opening schedules, check the option Save As Default. The next time
you use the Opening Schedule feature, your previous selections will
already be set.
