SoftPlaln reView Frequently Asked Questions
Is there a charge for SoftPlan reView?
Will I be able to import my customer’s comments and markups back into my SoftPlan drawing?
Will SoftPlan reView run on my Palm handheld device?
I currently send my designs to customers using a .PDF file format. Why would I use SoftPlan reView instead?
I use SoftPlan Version 11, can the reView module be added to my SoftPlan?
Will my field personnel be able to see all of the drawings on a handheld?
Is reView suitable for the creation of existing conditions drawings? Can I walk around an existing building and enter it into reView?
Can the framing diagrams for my houses be viewed in reView?
Will my clients be able to print the reView drawings?
I have SoftPlan Lite will I be able to purchase the SoftPlan reView module?
Why would I use SoftPlan reView to send drawings to my print shop rather than .PDF files?
I have a client that prefers .PDF files, how can I create .PDF files?
I have an older Windows CE device, will SoftPlan reView run on it?
How can my customers access the SoftPlan reView Viewer?
Can SoftPlan reView be downloaded directly to a Pocket PC device in order to install it?
Why send a reView file instead of a .PDF?
Can you mark-up and add notes to the different modes in a reView file?
The SoftPlan user that is going to author or publish the reView file will be required to purchase an additional module, SoftPlan reView. The viewer portion of SoftPlan reView can be distributed free of charge.
Yes, any information such as comments or sketches that your customer makes on the reView file will import back into the original SoftPlan drawing.
At this time reView requires a Windows PC or a Pocket PC to run the reView viewer and will not run on a Palm operating system.
reView maintains all the “architectural” information contained in the original SoftPlan file. So not only can you see the floor plan or elevation but you will know the size of the window or the height of the wall. A .PDF file on the other hand is more of a representation of a piece of paper.
No, SoftPlan reView requires at least SoftPlan Version 12
Will my field personnel be able to see all of the drawings on a handheld? >Back to Top
Yes, any SoftPlan drawing can be published as a reView file. So floor plans, elevations, details, and site plans will all be available for viewing on any Pocket PC.
Is reView suitable for the creation of existing conditions drawings? Can I walk around an existing building and enter it into reView? >Back to Top
No, reView is intended to view, annotate, and query technical drawings created in SoftPlan. Regular SoftPlan running on a tablet or laptop PC would be much better suited for the creation of drawings.
Can the framing diagrams for my houses be viewed in reView? >Back to Top
Yes, reView has the same modes as SoftPlan. To view the roof framing for example, open the floor plan and switch to roof mode, then the roof framing layout complete will display.
Will my clients be able to print the reView drawings? >Back to Top
Yes, but it is up to you. When the reView file is created the author decides if the resulting file will print or not. If printing of the file is allowed, then the author decides if the user can print it to scale or only to fit the page.
I have SoftPlan Lite will I be able to purchase the SoftPlan reView module? >Back to Top
No, SoftPlan reView can only be added to the full SoftPlan program.
Why would I use SoftPlan reView to send drawings to my print shop rather than .PDF files? >Back to Top
SoftPlan reView files are much smaller, roughly 10% of the size, so the files are easier and faster to transmit.
I have a client that prefers .PDF, files how can I create .PDF files? >Back to Top
In addition to creating reView (.SPV) files, SoftPlan reView can author .PDF files.
I have an older Windows CE device, will SoftPlan reView run on it? >Back to Top
reView requires the operation system on the handheld to be at least Pocket PC 2003 (sometimes referred to as Pocket PC Version 4). Older operating systems, Windows CE or Pocket PC, are insufficient.
How can my customers access the SoftPlan reView Viewer?  >Back to Top
The SoftPlan reView Viewer can be downloaded at http://www.softplan.com/lpreView_downloads.htm and is also located on the SoftPlan installation CD in the SoftPlan reView folder.
Can SoftPlan reView be downloaded directly to a Pocket PC device in order to install it?  >Back to Top
No, the installation program must be downloaded to and run from a PC which is connected to the Pocket PC device via Microsoft ActiveSync®.
Why send a reView file instead of a .PDF? >Back to Top
The advantage of a reView file is the ability to right click on a wall, symbol, window, etc., and get a description of the item’s properties. For example, right clicking on a wall will show the wall style and height. You can also run a cursor from one line to another to get the distance. This is a huge benefit to the client or engineer because they can instantly see the information. You can also link comments from the person who gave the comment so the person viewing the file can see who made the comment.
>Back to Top
Yes, the reView viewer allows clients to make mark-ups and notes in all of the modes available in SoftPlan. This keeps the notes organized in one file instead of different sheets in a .PDF. The mark-ups made in any mode will be displayed in that mode when the drawing is brought back into SoftPlan, and the mark-ups will appear in the reView mode. This feature also offers a lot of flexibility to the person exporting the review files. Visibilities and screen colors of items can be set up anyway you want for each of the different modes using Visible Items, Layers, or Building Options. Besides obvious options like a plumbing or HVAC mode, you can separate dimensions, furniture layouts, etc. from the main drawing mode if desired. This allows clients an uncluttered view of the floor plan, but still gives them access to other information.
Copyright©2006 SoftPlan Systems Inc.
