Cabinet Layout
SoftPlan provides a variety of commands and automated features to make the placement of cabinets simple and customized for your specific building requirements. Cabinet libraries offer hundreds of pre-defined cabinet symbols that can be readily added to plans.
When a detailed cabinet selection and placement is desired, cabinets maybe drawn individually with user defined dimensions, finishes, and styles. Or, an entire run of cabinets can be drawn quickly using the Auto Cabinet feature. This feature allows you to sketch in where a single style of cabinets is to be placed while SoftPlan automatically determines widths to best fit the available space. The run of cabinets is also adjusted to avoid windows, doors, and appliances.
SoftPlan allows you to edit for items such as hardware, finish, and countertop which can  be extracted to the 3D rendering for a life like appearance. Create custom cabinetry such as islands and blind cabinets quickly with SoftPlan’s powerful drawing and editing tools. As with many other items in SoftPlan, if further customization is needed, you can create your own libraries or modify existing ones.
