Placement of Cabinets Next to Each Other Improved
Version 12 has improved the program's
ability to automatically place one cabinet next to another. When you draw
a cabinet along a wall, the back of the cabinet will snap the edge of the
wall. Also, a cabinet drawn next to an existing cabinet will automatically
snap the new cabinet next to the existing cabinet and bind them together
to form a continuous cabinet run. Cabinets can also be bound together back
to back as in the case of an island. The placement of cabinets next to
each other has improved compared to previous versions to avoid cabinet
binding together when not desired. An example of this is two cabinets on
opposite sides of a wall. Previous version may have snapped the cabinets
together back to back through the wall as the distance between each
cabinet was within their snap tolerance. Version 12 now recognizing the
wall between the two cabinet runs and no longer snaps them
together.
Counter Tops Have Pen Selection Increased to 16
Counter Tops Pen Selection has
increased to 16. Previous versions of SoftPlan would only have 8 pens to
choose from.
Load a drawing that has
cabinets.
Click on Edit > Edit Item.
Click on the Cabinets.
Click on the Cabinet Run /
Counter Top tab.
Click on Print so that it is
selected.
At the end of the Print Pen
text field, click on the down arrow button, the selection here has
been increased to 16 from 8.
Placing of Cabinets Next to Walls Improved
walls is improved. Previously, when parallel walls were drawn in close
proximity, an edit of the cabinet to remove it from cleanup would
sometimes be necessary in order that the cabinet maintained its placement.
This step is no longer required
Select Draw > Cabinet
>Plan View > Library.
Click the insertion point of
the cabinets.
Move the cursor in the
direction to drawn the front of the cabinet and click.
SoftPlan will snap the cabinet
to the wall.
Reverse of Cabinets Improved
ability to automatically reverse plan view cabinets. Once a run of
cabinets, or an entire floor plan is reversed, the cabinets will now
reverse with more predictable results. The result is a more accurate
reversal of a floor plan, including all cabinet layouts.
- Open an existing plan that contains a
run of cabinets.
- Select Edit > Reverse.
- Form an expanding box that fully
encompasses the entire floor plan layout, including the
cabinets.
- Specify a direction for the
reversal.
- The plan, including the cabinets will
properly reverse.
