Why does a box sometimes appear in place of my small dimension numbers?
Version(s): 10
A small box symbol will replace a dimension number if the number overlaps other items on the screen. To display the number, use the Move command to move the number to an area with more room.
Versions(s): 11, 12, 13 +
A small box symbol will replace a dimension number if the number overlaps other items on the screen. To display the number, use the Move command to move the number to an area with more room. To prevent this from happening again, go to File > System/Drawing Options > Dimension Options and select the option for ‘Offset Small Dimensions’. This will offset the dimension number outside of the space allotted for the dimension in order to display it.
