Where do I set up the pen settings for Walls?
Version(s): 10
All pen settings are assigned from within the Wall Definition menu, on a per material basis. To change, select File
> System/Drawing Options > Define Walls > Edit > and select the wall to change. Each material will have
a pen setting for both the outside and inside lines, as well as the texture being used. Note that these settings
are used only if the material has been set to be visible. As the walls have already been pre-defined with Pen
numbers, you may want to accept those settings and set up your other items with the remaining Pen numbers, as it
would be much easier to change those than to edit each material of each wall type.
Version(s): 11 +
> System/Drawing Options > Define Wall > Edit > and select the wall to change. Each material will have
