When placing joists on the main floor plan, how do I locate where the beams are in the basement plan below?
Version(s): 10
Within Floor Joist mode, select Draw > Overlay and select the basement floor plan. A dotted outline of the walls, beams and posts will be onscreen allowing you to accurately place your floor system.
Version(s): 11 +
Within Floor System mode, select Draw > Overlay and select the basement floor plan. A dotted outline of the walls, beams and posts will be onscreen allowing you to accurately place your floor system.
