When importing a .DWG or .DXF file from another program, a message appears stating that the
drawing is outside of the SoftPlan world and the import fails. Can this be corrected?
Version(s): 12, 13
The drawing most likely needs to be drawn closer to the 0,0 point in the originating software. Ensuring all items
have been moved closer to 0,0 will usually allow the .DWG or .DXF to successfully import within the SoftPlan
world.
