When I try to use Auto Dimension, I get an error message that says, “SoftPlan was unable to Auto Dimension this case.”
Version(s): 12, 13 +
SoftPlan looks at the building perimeter for walls and beams that are bearing. If it cannot find a complete enclosure that is bearing, it will not Auto Dimension the floor plan. 1) Make sure that the walls you have on the floor plan are bearing walls. 2) Make sure that the walls join properly at the corners.
