When I try to select the Copy to SoftPlan Clipboard or the Paste from SoftPlan Clipboard
commands, they are grayed out.
Version(s): 11, 12
You need to disable the Multi Drawing feature in order to select those two commands. Select > File > Multi
Drawing and remove the check from Enable, select Ok. This will disable the Multi Drawing feature. You will now be
able to select Edit > Copy to SoftPlan clipboard.
