When I try to generate a cross section, why does the following message appear: "The lowest
floor in the assembled floor stack does not have a section line?"
Prior to Version 14, the cross section lines had to be added to the lowest drawing in the building
plan. To correct, simply add a section line to the appropriate drawing and ensure that they are assembled in the
proper order under the Build menu.
