When I create a custom Electrical symbol, how do I get the green reference points that the
electrical connections attach to?
Version(s): 11 +
The green reference points are Construction Points. Use ctrl + Right Mouse Click (or Tools > Construction Point)
to place the Construction Point where you want the electrical connection to join the symbol. It will initially
appear as a red plus sign. When you add the symbol to the Electrical Library, it will become the green reference
point. If you are going to modify some of your existing electrical symbols, they should be exploded before adding
them back to the library.
