When I attempt to dimension between walls, the dimension line continues to pick up lines?
When any of the Dimension/Extension functions are selected, the default setting in the Status Bar located just above the icons, will have ‘Shape Dimension’ checked. To bypass any shapes when dimensioning, which would include lines, simply take the check off of the ‘Shape Dimension’ function prior to running your dimension string.
