When I am drawing walls and shapes I notice that the command will stop. Why do I have to
restart the drawing process?
Version(s): 12, 13 +
The drawing process for some items, such as walls, lines and railings, for example has changed. If you start the
draw command and continue to draw until it ends on the same object it will terminate the draw command
automatically. For example, in drawing a partition wall between two walls, start the partition on one wall and end
on the other wall. The partition wall will terminate at the intersecting wall. Then the cursor is free to begin
elsewhere on the plan to continue drawing more objects. This eliminates having to use the Escape key or cleanup
each time the command is to be completed and the cursor needs to be repositioned to draw.
