When I add my openings, the Opening size displays and I would like the Rough Opening or Product Code to be
displayed.
Version(s): 11 +
There are two solutions available:
1. Prior to drawing the openings: Go to File > Drawing Options and Dimension Options. In the Openings Section of
the dialog, checkmark the appropriate options you would like displayed. More than one can be selected and
displayed. Once this is set at the Drawing Level, it should also be changed at the System Level so that new
drawings will be displayed with the desired options. Go to File, System Options and Dimension Options.
2. If the openings have already been drawn: In the drawing, go to Edit > Edit Item and Edit the Opening.
Click on the Display tab and in the Opening Text Section, select the Opening Text that you would like to display.
Note that the Product Code will not display if the Product Option is not checked on the Plan tab. To make this
change to the remaining openings on the drawing, use Repeat Edit, Repeat Edit (Box) or Repeat Edit
(Poly).
