When I am drawing walls and shapes I notice that the command will stop. Why do I have to restart the drawing process?
If you start the draw command and continue to draw until it ends on the same object it will terminate the draw command automatically. For example, in drawing a partition wall between two walls, start the partition on one wall and end on the other wall. The partition wall will terminate at the intersecting wall. Then the cursor is free to begin elsewhere on the plan to continue drawing more objects. This eliminates having to use the Escape key or cleanup each time the command is to be completed and the cursor needs to be repositioned to draw.
