What if I have enlarged my fonts in the Character Setup but some of my notes did not update to the new size?
These notes have likely been set to a Custom Size. To have these notes use the default settings, select Edit > Edit Item and set the Font to Default. Use the Edit > Repeat Edit or Repeat Edit (Box) or Repeat Edit (Poly) and select other notes to also update them. There is an option under Notes > Review. This will list all of the notes on the open drawing. The default box can be checked for each note. The default will revert to the settings defined in the Character Setup.
