SoftPlan Frequently Asked Questions: Walls
  1. I have 3 different walls meeting at a T-intersection. How can I get them to join properly?
  2. Can I add my custom walls from an older version without recreating them?
  3. Using Adjust Item to lengthen a wall to intersect with another wall often redisplays the adjusted wall as angled?
  4. Can the distance a beam projects out into a wall be controlled?
  5. When I change from an 8" Concrete Block wall to a 10" Concrete Block wall
  6. Change Wall command does not change the wall heights. How do I correctly accomplish this?
  7. Cleanup is not removing portion of walls that bisect with one another? How do I change this?
  8. How do I concurrently adjust the length and the angle of a line or wall?
  9. Is it possible to copy the Wall Types from a drawing and import them into the System Options/Wall Definition List?
  10. My custom defined wall is not showing in the Drawing Wall list. How do I correct this?
  11. How to get a cut out for Garage doors in the Foundation?
  12. How to display my walls in a Solid format for presentation work?
  13. How do I draw a wall on an angle?
  14. How can I show and print a wall which is to be removed as dashed?
  15. How do I break a wall?
  16. How do I create a 3.5" partition wall that is bearing?
  17. How do I create a Concrete Wall with a brick ledge?
  18. How do I draw caissons beneath the basement walls?
  19. How do I modify the footing sizes on my walls?
  20. How to generate a Wall Panel Diagram?
  21. How do I make a beam maintain the offset I have given it?
  22. What determines which item is going to move with a wall that is being moved?
  23. My brick wall is stopping short of the siding wall how do I reverse it?
  24. My walls are not forming a proper corner. One wall continues to overlap the other? How do I correct this?
  25. How do I keep walls from joining every time I run a Cleanup?
  26. How do I slope the top of a wall for a Vaulted Ceiling or for a sloped Retaining Wall?
  27. How do I draw a wall of half block or half concrete and half frame?
  28. My walls are protruding through the roof since I changed the wall heights. How do I correct this?
  29. When drawing a wall what does the trace line represent?
  30. Why don't my short walls clean up properly?
