Please read the instructions below to download patch files:
The SoftPlan patch is a self-running program available in both a DOS and a Windows version. It is incremental, which means that you must have run the number 1 patch before you can run the number 2 patch, before you can run the number 3 patch, etc..
These patches will not download to AOL native browser. We recommend Microsoft Explorer®.
Download Instructions:
Click the Download button
Copy the patch file to your SoftPlan directory.
If installing from the DOS command line: Change to your SoftPlan directory by typing CD \SOFTPLAN. Type DnnnPTCH.EXE where "nnn" is the patch version number. The patch process will begin.
If installing from Windows 3.x: From Program Manager select FILE, and then RUN. In the Command Prompt window type C:\SOFTPLAN\WnnnPTCH.EXE where "C" is the drive on which SoftPlan is installed and "nnn" is the patch version number. The patch process will begin.
If installing from Windows95: From the Task Bar, click on the Start button. On the Start menu click on RUN. In the Open window type C:\SOFTPLAN\WnnnPTCH.EXE where "C" is the drive on which SoftPlan is installed and "nnn" is the patch version number and then click on the OK button. The patch process will begin.
