- Building Options
Building Options Ability to Lock Added A Lock selection is available on the Building Options dialogs. Items assigned to the Building Option cannot be erased...
- Area
Area Area Exclude Rectangle Command Added Area Exclude options have been added to Area Mode. Using an exlude command allows sections of an enclosed area to be excluded from the...
- Beams
Beams Beam End Profile The beam end style can be specified in edit beam end style, in addition to the Plumb and Rake settings with the ability to set the profile through...
- Cabinets
Cabinets Adjust of Cabinet Run Allowed Watch Movie Allow Countertop Property Added to Symbol When seleted, a run of...
- Ceilings
Ceilings Ceilings Included When Drawing Rooms in Room Mode Dimensions and Extensions Can Be Added in Ceiling...
- Color
Color Cursor Color Configuration Added The assigned colors menu gives the ability to change the setting for the cursor to your own preference. When the color is...
- Copy
Copy Select Move Point Option Added to Copy Block This feature will allow the selection of an exact point as a "handle" for the copy. ...
- Cross Section
Cross Section Cut Lines Can Be Added to any Drawing in the Assemble Floors List A section line can be placed on any floor in the assembled floors list. A cross...
- Decks
Decks Champher Option Added The champher option has been added to decking. Using champher creates a more realistic 3D view. Watch Movie Deck Joists Can Have...
- Dimensions & Extensions
Dimensions & Extensions Auto Dimension Added to Default Toolbar The auto dimension icon is now available in the dimension icons group on the default tool bar. ...
- Drawing
Drawing Add End Panel Option Added to Rod & Shelf Drawings in Memory Are Indicated With a Graphic Icon...
- Edit
Edit Access to Wall and Beam Definition Added to Wall and Beam Edit Dialog Answer to the "Align" Question on...
- Electrical
Electrical Additionial Electrical Icons Added to the Toolbar This allows more library items to be assigned shortcuts on the toolbar ...
- Elevation
Elevation Sun Studies Can Be Completed in Elevation Save Elevations, Sections, and Roof Plans Has an Option...
- Erase
Erase Items Must Be at Least Partially on Screen to Be Erased This will prevent the property lines from being removed when erasing other items when zoomed in on a...
- File
File DWG and DXF Export of a SoftView Model Can Include Textures DWG AutoCAD® 2007 Files Import DWG/DXF Export...
- Floor System
Floor System Cleat Command Added This new command places a Cleat or Plate on top of floor joist to support roof framing. This is useful for designs...
- Interiors
Interiors Additional Wall Covering Icons Added In Version 14 the additional wall covering icons added allow more and different style of wall coverings...
- Lathe
Lathe Lathe Template Used to Create Turned Profiles to Be Placed Into the Lathe Library Use the Lathe Template to create custom shapes for the stairs Posts, Newels,...
- Layers
Layers Ability to Lock Layers Feature Added A Lock selection is available on the Layer Setup dialogs. Items assigned to the Layer cannot be erased or moved....
- Miscellaneous
Miscellaneous Add Product Code Added to the List of Password Protected Configuration Settings Glulam...
- Modes
Modes SoftList Mode Added SoftList Mode is used to estimate quantities for both SoftPlan and non-SoftPlan (imported .PDF or .DWG files). ...
- Move
Move Align to Edge Can Access Walls on an Overlayed Drawing The Align to Edge can be used in a situation where one object on a plan needs to align its...
- Notes
Notes Auto Label Wall Only Displays Significant Digits of the Height Extra zero have been removed from wall heights so that only significant digits are displayed in...
- Openings
Openings Arch Chamfered Maintains the Size of the Chamfer As the Width of the Arch Is Changed Baseboard...
- Paint
Paint Arc Cords Do Not Act as a Paint Boundary Line Styles Maintained When Pattern Is Defined Paint and Shade Break Lines Use the Shape Auto...
- Pen Assignment
Pen Assignment Print Pen Override Added to the Edit Symbol and the Electrical Symbol Dialog With the Print Pen override that has been added to the Edit Symbol and...
- Posts
Posts 20 High Quality Columns Added to Library SoftPlan now has 20 new columns in its library of predefined posts. ...
- Print
Print @Print Commands Added for Project Information Entered Under File-Project Information @Scale Print Command...
- Railings
Railings Deflection Option Added Intermediate Post Option Has Been Added ...
- Roof
Roof Add Shed Roof Command Added Watch Movie Adjust a Roof Reference Point onto a Curved Wall and the Roof Edge Becomes Curved Apply Gable...
- Roof Framing
Roof Framing Dimensions and Extensions Can Be Added and Edited in Roof Mode Attic Truss Type Added Attic Truss has...
- Room
Room Butler Pantry, Storage Room, Screened Porch, Deck Room, Game Room, Patio, Mud Room, and Hearth Room Added ...
- Shapes & Solids
Shapes & Solids Invert Option Added to Solids Pyramidal Frustum Added ...
- Site
Site Generated Grade Lines Automatically Display a Shot Point at Each End Indicating Height Grade Lines can have the elevation changed via the edit dialog. ...
- Snap
Snap Center of a Curved (Radius) Wall Is a Snap Point The Cursor Snap command is now able to locate the Center radius point of a curved wall. ...
- SoftList
SoftList Add Banner Command Added SoftList now allows a logo to be added to the printed report. Add Companion Material...
- SoftPlan reView
SoftPlan reView 3D Review Added SoftPlan reView 3D allows SoftPlan reView users to send the 3D SoftView model to clients for viewing. The free reView client...
- SoftView
SoftView .3DS File & SketchUp® Files Import/Export Added to SoftView The new Symbol Wizard command allows 3D symbols to be imported directly from SketchUp®. 3DS...
- Stairs
Stairs Automatic Labeling Added to Stairs When you edit a stair the following automatic labeling functions are now available; Add Direction Arrow, Add Riser Count,...
- Symbols
Symbols Always Face North Option Added to Symbol Definitions The Always Face North Selection has been added to the Symbol Definitions. This feature is used to...
- System Options
System Options Archive Backups and Restores the Softview.cfg File Containing the Default SoftView Settings Option Added to Draw...
- Tools
Tools Adjust Wall Material Command Added Difference Command Added The Difference command is...
- Type Erase
Type Erase Items Added to Type Erase: Take Off, Layers, Building Options, Posts, Area Schedules, Electrical Legends, General Tables, Opening Schedules, Room...
- Visible Items
Visible Items Display Print Pen Style Option Added The line weights that SoftPlan will print items with can be displayed on the drawing using the...
- Wall Framing
Wall Framing Add Header Command Added This command is used to place a single header over multiple openings. ...
- Walls
Walls 6" Concrete Wall Definition Added to Lite Banding Finish Options Added When drawing banding, a list of default...
- Zoom
Zoom Block Commands Such as Move Are Not Interrupted by Zoom Watch Movie
