Using Adjust Item to lengthen a wall to intersect with another wall often redisplays the adjusted wall as angled?
Select Tools and turn the Snap feature off. With the snap feature enabled, SoftPlan will attempt to join walls endpoint to endpoint, even if it means changing of the angles of the wall, prior to any cleanups. However with the snap feature off, the SoftPlan cleanup feature attempts to join walls by lengthening them by up to 6" to form a corner.
