The Extend command isn't working the same way it did in earlier versions.
This command has been modified. To use the Extend command, you first click on the extend line you want to extend
other lines to. Then click on the side of the line you want extended. For more information on the Extend Command,
refer the Lesson for using Tools in the Learning SoftPlan Manual.
