SoftPlan is not retaining the function I select?
When making a selection within Windows, the system will process where the initial click is released. For
example, if the Erase menu is opened, and the mouse button is pressed to select Item Erase, however it is not
released until the cursor is passing over the Part Erase, then the function selected will be Part Erase. Be sure to
make a quick click and release on the intended command from the pull-down menu or icon on the toolbar. To ensure
you have made the correct selection, be sure to check the Function selection listed in the upper left
corner.
